Home > Help Needed / General Tech Chat > Oh yes other question
vrooom
Member #: 138
*wink*
Can turbo box being welded while engine is in car, cylinder head and exhaust mainfold removed?
jay
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
probably... but you risk getting sparks and grinding dust in the engine!
Not to metion you make the job twice as hard as needed!
alex
AlexF
it can also be done with everything in, you could weld it from the back....
top seam would have to be done from the front but would be fairly straight forward with everything in.
Not the easiest option mind, especially when a good hour's work gets the engine out easy enough.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
get the engine out!
last thing you want to do is set fire to the remaining petrol etc etc....
alex
AlexF
