| Home > Help Needed / General Tech Chat > NEED HELP!!!!! | |||||||
12th Jul, 2007 at 09:00:39am
Ok the clutch was slipping a bit so i thought i would change it. finished last night and it dont work.
12th Jul, 2007 at 09:04:39am
maybe the master or slave was on its way out, the extra of the double grey sent it over the edge.
12th Jul, 2007 at 09:12:56am
the first time i put the pedal down after doing the clutch it was very spongy. or should i say nothing there. pumped it 10 times and felt some spongy then another 20 pumps and could get a gear!
12th Jul, 2007 at 09:29:35am
are you sure its correctly adjusted on that little nut that presses agains the arm? |
12th Jul, 2007 at 09:37:07am
pulled the arm fully out by hand and adjusted the bolt out till it touched. turned it back about 3 flats, so slight play. |
12th Jul, 2007 at 09:50:12am
Have you bled the system?
12th Jul, 2007 at 09:59:07am
should i need to bleed the system? i didnt do anything to the hydraulics. plus i did give it one bleed after finding this problem and made no difference. |
12th Jul, 2007 at 10:00:23am
I'd also say bleed it, they can be funny buggers, the way I do it is a long length of clear pipe (washer tube ideal) from the slave bleed nipple back into the top of the master cyl, that way you can just keep pumping it round and the bubbles will float out in the master (hopefully!)
12th Jul, 2007 at 10:05:35am
but it was working and i didt touch the hydraulic bits.
12th Jul, 2007 at 10:12:52am
On 12th of Jul, 2007 at 10:05am Turbo Shed said:
but it was working and i didt touch the hydraulic bits. Matters not in my experience, bleed it again to be sure. At least it is something to eliminate if nothing else.
12th Jul, 2007 at 10:25:43am
i'm trying to bet a master cyl today and will bleed the old one tonight and if that fails i'll change it tonight.
12th Jul, 2007 at 10:30:55am
you know all the best cars come on trailers |
12th Jul, 2007 at 10:36:21am
Trailer? what. its in road legal class so it goes on the road. also i dont have a trailer.
12th Jul, 2007 at 12:26:17pm
any other ideas? even totally random ones.
Edited by Turbo Shed on 12th Jul, 2007. |
12th Jul, 2007 at 12:40:57pm
Have you bled it? Any better?
12th Jul, 2007 at 12:49:36pm
come on im at work. will try bleeding and then changing master cyl tonight. if that fails, some other ideas would be nice. |
12th Jul, 2007 at 01:37:53pm
Work? HA! No such grind for me until Monday!
12th Jul, 2007 at 01:57:33pm
Ha, i have this friday off and monday!!
