| Home > Help Needed / General Tech Chat > Kangarooing.... please help! | |||||||
![]() 124 Posts Member #: 1428 Advanced Member Cleveleys |
17th Jul, 2007 at 05:15:40pm
Hi there guys
998 turbo in progress.... DONE..........KNACKERED LOL |
17th Jul, 2007 at 05:31:33pm
gasket between the plenum and carb the right way round?
17th Jul, 2007 at 05:58:02pm
what gasket do i need then? ATM i'm using a standard paper HIF gasket!!!
17th Jul, 2007 at 06:00:39pm
basically make sure all the holes are where they should be and your not blocking any off.
17th Jul, 2007 at 06:14:30pm
ah right, thats pretty detrimental to a turbo car running i guess!!
17th Jul, 2007 at 06:18:52pm
yup. |
17th Jul, 2007 at 06:19:14pm
Yes it is fella. |
17th Jul, 2007 at 06:28:21pm
right oh, cheers lads.
17th Jul, 2007 at 06:35:26pm
hopefully it is |
18th Jul, 2007 at 08:08:01am
could also be the turbo to air filter pipe sucking flat, or the standard fuel filter in the tank. |
18th Jul, 2007 at 08:48:42am
have you inspected the balnce pipe (from front of carby to float chamber , it generally crank and leak, so float chamber doesn't see boost) |
20th Jul, 2007 at 08:59:57pm
Well i checked the gasket.
20th Jul, 2007 at 09:13:04pm
seem that the float chamber doesn't see the pressure, where is going float vent pipe? |
20th Jul, 2007 at 11:05:03pm
Fab, which vent pipe do you mean? the balance pipe?the one from the side of carb to the fron of carb.
20th Jul, 2007 at 11:11:52pm
you have three pipes going to the floart chamber , balance pipe (front one), fuel feed (back lower one), vent pipe (back upper one) |
20th Jul, 2007 at 11:36:03pm
ah right.
20th Jul, 2007 at 11:52:37pm
fuel vent pipe needs to be blocked.
21st Jul, 2007 at 12:05:08am
Cheers Iain
21st Jul, 2007 at 08:19:32am
use a t piece from plenum boost piping and connect it to float chamber it'll assure that you have a strong signal when you going from vacuum to boost, blocking the balance pipe is not a good idea if your using this car daily,
21st Jul, 2007 at 03:33:48pm
Hi just blocked the vent pipe and it drives much better. Still need to look at the fuel and ignition. But No more Kangaroo 998 turbo in progress.... DONE..........KNACKERED LOL |
21st Jul, 2007 at 04:34:11pm
nice one |
