Home > Help Needed / General Tech Chat > Almost starting
Zeemax Power
Member #: 393
Oulton Park
Stuck again lol. Got standard 1275 and complete swooped to a 998 apart from eletrics and carb. The problem i'm having is i just can't start it. It's almost there it's firing but somethings not quiet right just wondered if anyone had any ideas. I have fuel at the plugs and a good spark and its timed right whats the next port of call??
cheers
http://www.Zeemax.com
MarkGTT
Member #: 1194
Shropshire.
Hi, Check for air leaks on the inlet manifold, carb spacer etc. Have you attached an earth strap?
Cheers Mark.
My god, you seem to be having the worst luck at the moment with engines:(
Leonard
Member #: 806
Cirencester, Gloucestershire
is it a 998 carb or the same 1275 one? it maybe that the mixture is miles out
Zeemax Power
Member #: 393
Oulton Park
i've swoped to different carbs over and other not quiet working. inlets off my 1275 does that make any diffence with it being a 998 set up.
Bit comfused! Got good earth strap to the engine. Inlets i dont think are leaking but i'll check tomorrow.
colas
Member #: 102
Pennsylvania USA
Plug leads the correct way? Have you had the dizzy drive out?
Zeemax Power
Member #: 393
Oulton Park
good and good and no
1380turbo
Member #: 1211
Working up the BHP ladder.
was the 1275 running ok befre you swapped it?
Zeemax Power
Member #: 393
Oulton Park
was running yes. you really cant believe how close it is to going night really
JT
Member #: 637
Hertfordshire
may sound obvious but i nearly forgot untill my dad said, have you put the rotor arm in the dizzy? from when you took the cap off??
coil rwired up propoly?
cheers
josh
My build thread..
Zeemax Power
Member #: 393
Oulton Park
yeah i have a spark and fuel its the weirdess thing. Check compression next cheers any other thought welcome
1380turbo
Member #: 1211
Gotta be either a very weak or very rich mixture? If it was running and all you changed is the carb the fault must be there.
