Home > Technical Chat > Hypatech pistons
turboestate
Member #: 362
durham area
Has anyone used the above pistons in a turbo motor and are there any problems with them, (with hastings ring set 73.5mm)
Edited by turboestate on 21st Jul, 2007.
love that straight cut scream!!!
______
/___|_____
_ (@)___(@)
slinkey inc
Member #: 1645
Adelaide Australia.
People use them here in Aus in all sorts of motors, N/A, turbo, whatever. I've never tried them though.
Supercharged 1964 Morris 850 - Now 1330cc with 7psi.
http://www.cardomain.com/ride/2466560
benjamin
Member #: 621
nsw austalia
im using 1100+60 hypatec pistons + hastings rings atm for 10psi boost with no troubles done 10,000km on them.
very cheap too
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
turboestate
Member #: 362
durham area
Thats good then ive just purchased a set of brand new 73.5s with rings for £135 including postage well chuft:)
______
/___|_____
_ (@)___(@)
nutter driver
Member #: 47
Not very sunny swanage
jesus thats cheap.... where was that from?
search on e bay
these look good guy pistons
turboestate
Member #: 362
durham area
On e-bay it was either these or shell out for some acralites from avonbar.
______
/___|_____
_ (@)___(@)
Sir Yun
Member #: 1592
Smart Guy!
just got a 998 set and a 1275 set in (5 days from Oz to here.. 14 days for customs to figure out how much VAT they where going to charge me)
the larger sizes are the ones without the slots.
1275 +96/73mm:
998 +120 ! :
Edited by Sir Yun on 19th May, 2008.
I bought a set (73mm) from Minisport Australia (through this site, he advertises in the "for Sale" section).
Also the larger ones without slots...
I will be using with turbo (but my project is taking far too long) but I haven't yet decided how much I dare machine out of their current dish, they only have 7.6cc as standard.
They need enlarging slightly otherwise I'll have to take enourmous amounts out of the head.
They look thick enough in the crown to have a fair amount machined out but the underside is a bit of a strange profile.
I also got them at a VERY good price - UK customs managed to ignore them and they came through with no extra UK duty/VAT (sometimes you get lucky!).
I guess the only way to tell is to cross section one and see how thick the crown is! *oh well*
At £30 odd a piston not as bad as cutting an Omega piston up! *laughing*
surely someone on here has access to an x-ray machine???
Maybe wolfie could keep one in his pocket? He seems to be the most unluckiest, then he could just flop it out on his next visit to hospital
Sir Yun
Member #: 1592
Smart Guy!
I'm seriously contemplation asking if i can get a radiologist friend to put it in a CT scanner (if his bosses don't freak out)
I've gone for the cheaper option..... I've depth gauged it from top and bottom and mapped the thickness.
Borrowing SirYun's photo, the areas it will go thin if I machine the profile I want is here.
They are 6.5mm to start in the centre, I don't want to go below 5mm in the centre, but with a shallow "U" profile (to get the maximum volume with 5mm in the middle) I'll be down to 3mm in those two very localised areas.
So I'm still undecided.
Rod.
Sir Yun
Member #: 1592
Smart Guy!
well i was planning on using them in a 16v twinkie..
liszabailey
Member #: 9254
Any opinions? hastings rings look like great quality from there website....but are really cheap. Im just doing a stock rebuild. (Car will be running ST autocross)
I had some cheap NPR rings that came with some other parts I bought....just for fun i tried to install them on a pistons and the 2nd ring snapped right in half. Glad they are not going in the motor.
For a D16A6
Lisza Bailey
Newbie
