Home > General Chat > Breaking a Ball Joint
b12
Member #: 247
Kent/Surrey Borders
Well ???
FUCKING hate it .... bastad shitty things EasyPeazy With a ball joint splitter EazyPeazy with the old hammer trick 4 Votes 4 Votes - 18%
TurboLessTosser
b12
Member #: 247
Kent/Surrey Borders
Hate the bastad thing Shit bastad shitty shit shit things
I do use the ol' hammer trick though *smiley* *smiley*
TurboLessTosser
evolotion
Member #: 83
Glasgow, Scotland
scisor ball joint splitterall others are useless., piece of cake. had a hub off today to replace the wheel bearing, took 30 mins all in, from jacking the car up to lowering it back down.
Denis O'Brien.
clubman_dan
Member #: 142
Winchester
use a scissor tyoe splitter, when i fitted negative camber brackets i had a go doing it the hammer way and ended up very pissed of, i went and got a splitter and it just came off no trouble, nice and easy
giallofly
Member #: 164
The Stig..
Newport Pagnell
Never had a problem with a fork type myself. Had the luxury of a good quality scissor type and an air gun a while back, that did make life alot easier.
Mine tend come off easily as i dont do mega miles between splits.
Once had a moment of muppetry years ago and greased the tapers, a big NO NO!!..could'nt get the fooking nut off the next time i split the thing, it just span!!..we live and learn.!!
evolotion
Member #: 83
Glasgow, Scotland
I find the fork type useless *tongue* but i do mega miles. had no luck with them atall, and broke several of the cup type, eventually jsut bought a scissor type and not looked back.
Denis O'Brien.
b12
Member #: 247
Kent/Surrey Borders
Fork types I have had no luck with at all
the one you get your ratchet on with the bolt that supposed to sit nicely onto the ball joint and push it out - Absolute BOLLOX
only the hammer and Jack teqnique has ever worked for me
I will now go buy the scissor type splitter as you all seem to have had some success !!
Steve
TurboLessTosser
T3Tone
Member #: 252
Sunny suffolk
Allways find leaving a bit of WD to soak in works a treat, especially the top one as it can get right in there.
-MINI CLUBMAN 1380 TURBO-
Well just to piss you off a bit, i removed two hubs, seperated driveshafts, removed those buts, took callipers off and packed them off into a happy customers car tonight all in 20mins! lol!
sykes pickavant sisscor splitter and an impact air gun!
Easy peasy!
Also much easier to remove the disc if you can easier to get into the joints.
Ive had cup and sisscor splitters and would only ever use my scissor one.
ps must learn to spell!!
jamesfawcett
Member #: 218
Bingley, West Yorkshire
i just use a ball joint splitter with hammer, never had no probs on any of the minis.
