| Home > Wanted > WANTED - ABS SENSOR - READ ON! | |||||||
25th Jul, 2007 at 11:09:12pm
Right then, in order to make the boost level alter in different gears in "The DON" I need an ABS sensor to use as a wheel speed sensor. This allows the ECU to calculate which gear you are in and hence alter the boost table according to a gear chart. All very clever stuff!
Edited by Tom Fenton on 25th Jul, 2007.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
26th Jul, 2007 at 06:28:49am
got a couple off a cavvy gsi i broke a little while ago. depends when you need it for though, as im unlikely to be able to dig it out until the early part of next week at best. not sure on mountings etc, ill have to wait untill i find it tpo see if it wil be any good......
And on the 7th day........... God created turbochargers! |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
26th Jul, 2007 at 10:43:58am
could you not so a similar system to those using electronic speedos with magnets and a pickup on the rear wheel tom? then its not affected by wheelspin lol On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
26th Jul, 2007 at 11:07:21am
could use a crank sensor, and put a trigger wheel onto the pot joint? On 28th Aug, 2011 Kean said:
26th Jul, 2007 at 11:19:53am
I'll have a look :) AlexF |
26th Jul, 2007 at 02:24:43pm
You need to check if you want VR or Hall effect. On 17th Nov, 2014 Tom Fenton said:
26th Jul, 2007 at 02:31:44pm
I can use either VR or a digital sensor, digital would be nice however I don't know anything that uses a digital sensor, unless anyone else does?
![]() 232 Posts Member #: 1197 Senior Member Dublin Ireland |
26th Jul, 2007 at 02:34:12pm
My Dad has loads of scensors in his garage Ill pop around tomorrow and see if he has any working ABS scensors!
