| Home > Help Needed / General Tech Chat > starting trouble | |||||||
141 Posts Member #: 162 Advanced Member |
9th Jun, 2004 at 11:58:11pm
well guys i have just finished my engine and its all installed, my battery was flat so i left it on charge for 8-9 hours and i got in from work and gave it a try but it was cranking over very slowly, i am going to leave it on charge over night and give it a go in the morning, would it just be the battery or is there something else i could try |
10th Jun, 2004 at 07:26:31am
could be a bad earth on the engine, or shagged starter motor or solenoid Team www.sheepspeed.com Racing
10th Jun, 2004 at 09:28:09am
Try cranking it over without your plugs in, get oil pressure up. Then try to start it. A jump from a starter pack is a luxury but from another running car will do.
Edited by giallofly on 10th Jun, 2004. On 21st Jan, 2011 fastcarl said:
10th Jun, 2004 at 08:14:10pm
yea the engine is fresh, i put a new battery on it, and it is still doing the same thing, i think i may need a new starter moter. i tried getting someone to tow me down the road and it wanted to start but it was caughing and spluttering, and backfiring. i put the dizzy from my old engine back on it and it is still doing the same thing, i am going to try my old coil on it aswell as they worked together before.
10th Jun, 2004 at 10:30:50pm
Mines a fresh rebuild too mate, been having the saem problems!!! ive been boosting off another battery but it still struggles. Mines turns over nicely with no plugs in and oil pressure comes up quick. Got it started for the first time tonight! fires up a treat, just need to leeson it up a bit now.
10th Jun, 2004 at 11:34:45pm
ok mate i will give it a go, is it ok to use the dizzy from my old 1000cc engine or would you reconmend not using this one. |
11th Jun, 2004 at 01:51:57am
it needs to be the turbo one i think dude cos of the advance curve On 20th Oct, 2015 Tom Fenton said:
11th Jun, 2004 at 07:04:07am
What I have done with the dizzy (which was also a 1000cc one) was to remove all the weights and weld it so it dosen't move. My timing is therefore fixed at 25 degrees.
11th Jun, 2004 at 07:45:58am
Advance wont be right but it should do the job for getting it up and running. Im running an mg metro one for the minute as i knew this was ok but ill swap it over when i start running some boost. |
19 Posts Member #: 169 Member |
11th Jun, 2004 at 09:18:48am
I Got mine running on a 998cc dizzy it ran like a pig but was good enough to get it going. my ignighter pack was bust but i was impatiant and wanted to start it so used the 998 one. would never drive on it though.
11th Jun, 2004 at 09:20:09am
ok i will have a play with the timing im sure it is ok though, i will also put a new set of plugs in it, is there any thing else i can try. just to let you know i converted from a 1000cc engine in a 1983 city shell, is the wiring ok for the job etc |
11th Jun, 2004 at 09:25:49am
all you need is a 12v feed to the coil (i.e. make sure you get that at the coil, you may have a ballast, im not sure), if your struggling with power to start also try putting a seperate battery on the coil, means that it sees a full 12v even when cranking just to rule that out.
