| Home > Show Us Yours! > Anybody ever had this with a Pre Verto Clutch arm? | |||||||
![]() 232 Posts Member #: 1197 Senior Member Dublin Ireland |
29th Jul, 2007 at 07:13:32pm
Well I finally got round to stripping my clutch down today.. been havin a couple of issues with full engagement of gears so I needed to go and have a look see..
29th Jul, 2007 at 07:16:05pm
Yeah...
AlexF |
29th Jul, 2007 at 07:20:56pm
Cheers Alex.. Ill stick that down as another point to be greased regularley.. TBH I never thought of it as Ive only done about 300miles in her since the engine went in and it was greased up on rebuild... must have missed it as Id say it was already well worn!!
29th Jul, 2007 at 07:35:04pm
minispares sell new ones
![]() 1840 Posts Member #: 54 Post Whore nr coventry |
29th Jul, 2007 at 07:57:05pm
i think its graphite grease that should be used on that iirc, i think thats the same stuff as CV joint grease, get a new one from minispares, dont think they cost alot
29th Jul, 2007 at 07:59:59pm
I've seen them worn like that and also worse.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
29th Jul, 2007 at 08:01:52pm
yep seen that one before, not on mine luckily. check the socket on the end case make sure it 8nt chewed up or warn
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
30th Jul, 2007 at 02:18:54am
On 29th of Jul, 2007 at 08:01pm Richie said:
i personally would replace the arm and the pusher thingy as a pair. but thats just me. Richie
30th Jul, 2007 at 06:44:50am
unfochantly happens alot if you use double grey diaphrams just ask miniwilliams, and mini spares items aint as good as genuine ones even if they say they are genuine. hey mathew always looking for them bigger bunches of bannanas |
30th Jul, 2007 at 10:27:53am
You get a whopping big left calf muscle though
30th Jul, 2007 at 12:16:11pm
Looking at you clutch plate it looks a bit like one i took out recently. the outer part of the friction material has worn as you would expect but the inner part is like new. mine had done a couple of thousand miles so had a bit more wear.
30th Jul, 2007 at 01:19:29pm
the MS one i bought seems to be a bit more heavy duty than the std ones i've seen, course it could just be the std ones were all worn away...
30th Jul, 2007 at 01:28:59pm
Grease nipple good idea in principle, however I think it would be difficult to do it in a way that ensures the grease doesn't find its way into the clutch itself.....
30th Jul, 2007 at 05:26:19pm
Good point,
30th Jul, 2007 at 06:42:47pm
On 30th of Jul, 2007 at 05:26pm mini13 said:
also my wok has so many holes in it you'd be able to se if ther was too much grease lol. Mines the exact same, like swiss cheese ...
well I ordered a replacement clutch arm and plunger this morning... hopefully have em in the next 2days! I think a grease nipple would be a good idea if mounted correctly
30th Jul, 2007 at 08:54:01pm
On 30th of Jul, 2007 at 06:42pm hughesmarkie said: On 30th of Jul, 2007 at 05:26pm mini13 said:
whats the matter with leaving ure nipples where they are, just wipe the grease back off before putting ure t shirt back on fools ! tish.....
31st Jul, 2007 at 01:53:59am
On 30th of Jul, 2007 at 08:54pm Richie said: On 30th of Jul, 2007 at 06:42pm hughesmarkie said:
faace of the flywkeel was a bit worn.. but couldnt be the answer to the problem I was having
