| Home > Help Needed / General Tech Chat > Oil pressure | |||||||
![]() 902 Posts Member #: 111 Post Whore Loughborough |
30th Jul, 2007 at 11:43:22am
Hi guys,
30th Jul, 2007 at 11:50:47am
that seems very high on idle, it could be opening the relief valve hence dropping.
30th Jul, 2007 at 12:13:17pm
What car/engine?
30th Jul, 2007 at 12:14:23pm
Sounds like the PRV is sticking. Sounds like its taking alot of pressure to open, and then not fully closing once opened?
30th Jul, 2007 at 12:18:20pm
Engine is a 1380 morspeed engine with MED head. The PRV i changed awhile for the ball bearing type thing. Not sure on the oil temp. How to i wind the pressure down?? is there such a think as a adjuster?
30th Jul, 2007 at 12:29:29pm
I've had funny oil pressures when using the ball bearings for the RV. Put a standard one back in and it'll work fine I reckon. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
30th Jul, 2007 at 12:44:49pm
put some black tape over the gauge and ignore it till the engine blows?! |
30th Jul, 2007 at 12:56:53pm
did you shorten the spring when fitting the ball? |
30th Jul, 2007 at 01:06:53pm
I have had this,
30th Jul, 2007 at 01:11:26pm
also every suposed "cooper S ball and spring" kit i have ever delt with needs the spring cut down, I also prefer to use the std spring rather than the stiffer S spring as the std one seems to give a more stable pressure in my opinion.
30th Jul, 2007 at 01:24:43pm
Is it worth fitting one of these
30th Jul, 2007 at 01:26:14pm
No i didn't shorten the spring, i orderd the ball and spring from Minispeed years ago and i asummed that it would be correct. I should learn really. |
30th Jul, 2007 at 01:34:07pm
i'd just cut the spring as those adjustable thingys can weep oil a bit, although the balls can be a little bit inconsistent I still prefer them as they don't tend to stick. IMO better to have 10psi variation around 50psi than have a std one stick wide open On 28th Aug, 2011 Kean said:
30th Jul, 2007 at 01:49:54pm
as i said earlier, get the hot oil pressure down a bit and you should see a significant improvement. |
365 Posts Member #: 1211 Senior Member Working up the BHP ladder. |
30th Jul, 2007 at 03:30:57pm
On 30th of Jul, 2007 at 12:44pm Turbo Shed said:
put some black tape over the gauge and ignore it till the engine blows?! hmmmmm? Has anybody questioned the guage itself yet?
30th Jul, 2007 at 03:45:53pm
Im sure its not the gauge. It used to be in my kit car and read fine in that then i swaped it for another one as i wanted to keep the full face gauge. So i think its good, was alittle worried about having an air lock but it should of pushed any air out by now i would of thought. |
30th Jul, 2007 at 04:07:36pm
Cooper S ball and standard non-S spring (as recommended above) and you will get a lower idle pressure (that will be just about right). The S springs are too strong - hence why people cut them down. |
