| Home > Help Needed / General Tech Chat > Installing engine with manifolds mounted?---Mirage | |||||||
30th Jul, 2007 at 10:31:15pm
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
30th Jul, 2007 at 10:48:45pm
I managed to do this at the weekend with my minus, usin mirrage (inlet off) all I had to remove was the starter and alternator, I believe it was Iain that suggested it to me in one of my posts a short while back?
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
30th Jul, 2007 at 11:05:03pm
i did it with all mine mounted, but i cheated cuz iv got a flipfront On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
30th Jul, 2007 at 11:37:09pm
On 30th of Jul, 2007 at 11:05pm stefaz said:
i did it with all mine mounted, but i cheated cuz iv got a flipfront me too, so much easier |
30th Jul, 2007 at 11:45:47pm
![]() 171 Posts Member #: 621 Advanced Member nsw austalia |
31st Jul, 2007 at 08:36:13am
i install with everything except carbie + manifold goes in ok and thats with remote gearbox, so would be easier with rod change.
1152cc turboed mini clubman, most powerful 1.1L a-series?
31st Jul, 2007 at 05:25:07pm
I pulled mine out a few weeks ago with everything still on, turbo, carb alternator etc..
31st Jul, 2007 at 10:13:03pm
OK Cheers guys.
31st Jul, 2007 at 10:55:29pm
I always install mine totally built up, carb, Turbo etc. Never found it to difficult really ........ |
1st Aug, 2007 at 10:39:44am
Ive done mine built up too, even with the gear linkages attatched. Flip fronted thought. 1/4 Mile 14.3secs 96Mph Terminal 10psi of boost.
5th Aug, 2007 at 09:43:09pm
Well, in the end I mounted the lot but once i started dropping the engine in decided to remove the carb but left the inlet manifold mounted. Halfway in it was looking impossible with the angle I had the engine at given that I lift using the front cylinder head bolts which tilts the engine to help with the diff negotiate the subframe.
6th Aug, 2007 at 10:45:54am
i fit everything to my engine apart from alternator, in a normal roundnose, and slotted straight in on a bit of a forward angle when lowering in, it was easy.
