Home > Help Needed / General Tech Chat > Steering rack limiter kit
Mark1275GT
Member #: 886
London.
Anyone got a set of these ?
http://www.kad-uk.com/accessories.htm
Just scroll down on the webpage.
Would this give me a 2.2 turn.
Cheers.
KAD say the following right next to the photo:
"Where a restriction in steering lock is desired, these simple nylon collars slip over the end of the rack limiting movement. Simple to fit, uses would include preventing 13” wheels fouling wheel arches, saving CV ’s in rally or grass track cars or with 6 pot calipers."
Mark1275GT
Member #: 886
London.
I know what, but does it give me a 2.2 turn was what i asked:) anyone else use these..
why do you need 2.2 turns?
stefaz
Member #: 1656
stoke-on-trent
2.2 turns is the same as the quickracks fitted to the sportpacks. i'm guessing you're thinking of this because you dont want to fork out for the quickrack - they limit it enough to stop the 13s fouling, but not sure if its 2.2turns, may be slightly different either way. what is it you are needing to achieve?
danboy
Member #: 1381
Mark, Fitting the spacers to reduce the travel of the rack will not give you a quick rack. It's just the same as you turning the steering wheel less than you normally would. All you will achieve is a greater turning circle for your car.
A quick rack will give you the SAME wheel turn for LESS steering wheel input.
The spacers will give you LESS wheel turn for LESS steering input.
The spacers are of use to prevent oversize wheels fouling the inner arch but not much else.
regards
Dave
Edited by danboy on 30th Jul, 2007.
stefaz
Member #: 1656
stoke-on-trent
well thank you for expanding my knowledge too dave - just glad i have the quickrack on mine
If you are having problems with 13" wheels fouling the inner arch then these spacers are great. Easy to fint and do what they say on the tin.
As Danboy says though they don't affect the ratio of the rack just the maximum lock.
Mark1275GT
Member #: 886
London.
Great info... thankyou.
I wanted 2.2 as my mate has 2.2 on hes. he said there much better. so yes i was looking for a cheaper alternative. (tight git) *tongue*
Ill give em a try :)
the above is absolutely nothing at all, in the slightest, ever, to do with a 2.2 lock to lock quick rack.
all it will do is stop you achieving full lock, not get there quicker
Nick
Member #: 154
Midlands
do you think you could be a bit clearer joey?
i can't quite grasp what you're trying to say...
i know its hard budd, if you want ill draw you a picture LOL
stefaz
Member #: 1656
stoke-on-trent
lol il explain for you bud - the quick rack has a diiferent ratio to standard so your wheels will turn almost as far as the normal rack - when fitting the shims to the normal rack you are reducing the amount your wheels can turn
Kean
Member #: 341
aka T2clubby
South Staffs
Nick's sarcasm has fallen on deaf ears again lol!!
I got it.
Someone on here is a BAC.
