Home > Help Needed / General Tech Chat > intercooler ROUTING ...
b12
Member #: 247
Kent/Surrey Borders
Just wondering
I am gunna use 2" exhaust pipe and cut and weld the main routes out of steel to the intercooler
If i run 2" pipe over the standard metro rocker cover
Will i still be able to close my bonnet ???
Am going to mount the bonnet properly and make some vents for the turbo, rather than keep my bonnet as it is , ie lifted up at the back on the hinges with the ol; one nut per side trick ?
Steve
TurboLessTosser
jamesfawcett
Member #: 218
Bingley, West Yorkshire
do it, then let me know HAHAHA
can i ask you something, do you fancy making your work twice as hard, and making two of the exhaust pipe joining things? Look on jimsters website and see how he has routed his in the same way.
If you will make me one too ill pay you how much would you want? it would be helping me out alot.
Edited by jamesfawcett on 11th Jun, 2004.
Soton1310Turbo
Member #: 265
Southampton
You'll need to put the bonnet up on pins if you go over the rockers if it goes over any thing like mine
I've removed the internal bonnet supports too so the bonnet can be mounted 10-15mm lower but it's still well up.
If you do this be aware you will be stoped on a regular basis by coffin dodgers telling you your bonnets open *laughing*
PaulM
Member #: 206
HOW wide is the track on that mini
9 valves, 4 wheel drive, 3 cylinders, 1 turbo, which got nicked
Soton1310Turbo
Member #: 265
Southampton
Wide enough *happy*
Only 7*13 Superlites over 4pots on Mini hubs no dodgy spacers
jamesfawcett
Member #: 218
me too! mines same width 4 pots make them a extra inch or so wider dont they?
3/4 of an inch :)
Soton1310Turbo
Member #: 265
Southampton
4pots make no difference if your allready using late type hubs
It will make them wider if you've moved from drums though
billydude
Member #: 48
Leicester
wrong mate
as I am useing metro 4 pot vented drive flange's on my mini and they are three quarters of an inch wider per side *wink*
my 5x10s fill the standard plastic arches to the limit *wink*
although it has just dawned on me I also have the non vented on the clubby and they don't stick out so I'll be quiet Lol
Edited by billydude on 16th Jun, 2004.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Its nearly as wide as mine!!
Problem with that install is that there is no were for the air to flow to! It goes through the intercooler and then no were!
alex
AlexF
