Home > General Chat > O/T Shed, Garage Flooring....
Jason G
Member #: 1459
En-suite user
Braintree, Essex
In the process of building a shed for my car. I rent my place, so I can't concrete a base. Got to be semi-permanent just in case. Got a month to sort it out & crack on with car.
Any ideas people????
On 19th Jan, 2010 wil_h said:
Plywood
stick down a few bits of 4x2 and put ply over the top?
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Had to ask...building sheds involves wood. Scares me! Shit at carpentry, you can't weld bits back on like........
LOL!!!
You could mix up a really weak mix, 8-1 or something, that'll then break up easy with a sledgy if needed.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Shall be taking your advice TF & mini13. Got loads of pallets that our metal at work is delivered on. Done 2 vans worth already! :)
