Home > Help Needed / General Tech Chat > Grinding the new ball joints
Markie_D
Member #: 1660
Formally Mini_Uk
London
From what i have read, you are meant to use grinding paste on new ball joints.
how much do you grind off the ball. till it's smooth ?, should the flat part on top on the ball be rounded off etc. ? and do i use the fine end or the coarse end of the paste
ive done a search with not much luck.
any help would be great.
Thanks.
Shit Happen's
icklemini
Member #: 745
Northampton
i use a dab of fine paste - wiggle the ball inside the cup (by hand) to take off any of the 'high spots'. clean it all up and job done.. :)
new one on me ???
shim them up without springs firstley then fit the spring where required and grease them
ding dong, job done!
andeh
Member #: 97
Near Daventry, midlands
im sure this was covered before, but it might be wrong.
just do as icklemini sais and is definatly worth doing!
shane
Member #: 1246
Lowestoft, Suffolk.
I use a dab of fine paste on all mating faces (pin to seat and pin to domed nut, as cheap repair kits are shite!) tape up the thread and go nuts with it on a battery drill moving it thru all axis (angles) clean them up, add a little oil and move it again thru all axis it it feels smooth (no lumps or tight spots) fit them if not continue untill they are.
Shane.
Mark1275GT
Member #: 886
London.
On 10th of Aug, 2007 at 07:35pm BENROSS said:
new one on me ???
No wander why i couldn't do the bottom ones that well, coz i was shimming them with the springs in.. *oh well*
So shimm them with out the brings and thats that..
Would't they go loose after i put the springs in ?..
I even orderd more shimms.. coz i thought i needed 1 shim in between sizes. as it's rather too tight, or too loose///
Ill try that anyway..
Thanks ..
icklemini
Member #: 745
Northampton
the spring in the bottom keeps it 'quiet' as it wears out..
the spring holds the ball of the pin hard agains the cup so as a result doesnt show any play when checked..
Shim them up tight and by the time you have reached the end of the road, they will have bedded in. Re grease and they are good to go.
I havent replaced any in years, i re shim them so no need to do much else.
I have heard the lapping in thing on the non genuine items, but havent heard anyone mentioning it for Genuine joints
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Yes grinding seems to be more important with the cheap sets. I wish I knew that when I did mine! I just set them tight and within a few weeks I gave them a re-shim and they have been grand since.
On 7th Nov, 2008 Nic said:
naeJ
m
Markie_D
Member #: 1660
Formally Mini_Uk
London
How tight's tight ? till you cant move them at all ? As im having nothing but problems with mine :(
There rather too tight, as in cant even move them, or too lose.
Ive grinded them in ok.
I got them from minispares..
http://www.minispares.com/Product.aspx?pid=35318
I see there none GENUINE ones. this a problem ? or would the ones i have be good enough ?
Cheers...
Shit Happen's
Never lapped any in in my life. I use the Ms ones and have had no problems.
I've had an MS one snap, but ofcourse this might be due to usage. ( the car was sold)
Markie_D
Member #: 1660
Formally Mini_Uk
London
So them ones i got off minispares are made by minispares then ?
Plus, how stiff should it be when shimming them.. i get them stiff ish in the centre, but very loose on the edges..?
pain in the back gate this is lol..
Cheers.
Shit Happen's
