| Home > Help Needed / General Tech Chat > another measurement needed...lol | |||||||
7th Aug, 2007 at 01:30:24pm
Hi guys, please could some have a quick measurement of the cam sprocket? I need to know the width of the sprockets (inc boss) but don't have a spare sprocket to measure!
Edited by matty on 7th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Aug, 2007 at 01:46:19pm
Just measured two of them, different makes but don't know what makes.
Edited by Rob H on 7th Aug, 2007. Isambard Kingdom Brunel said:
7th Aug, 2007 at 02:15:00pm
Cheers mate, thats quite a big difference!!
7th Aug, 2007 at 02:32:35pm
I think it's simply a case of how many turns you put on the retaining nut. By fluke there's an article in this months mini mag about cam drives and if you look at the pictures there's clearly a visible difference with regard to how far the thread extends past the sprocket. Isambard Kingdom Brunel said:
100 Posts Member #: 745 Advanced Member Northampton |
7th Aug, 2007 at 04:44:26pm
you adjust the cam end float by machining that boss smaller (the 'step' on the cam-side). |
7th Aug, 2007 at 04:57:44pm
Doesn't the edge of the sprocket run up against the triangular thrust washer as opposed to running against the end of the cam? https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
7th Aug, 2007 at 05:52:49pm
runs against the end of the cam.. |
8th Aug, 2007 at 07:17:27pm
try to pick up a double cahin one, you'll have a little more space to seal it , if that's the trick.
