Home > Help Needed / General Tech Chat > Rear Drums
Zeemax Power
Member #: 393
Oulton Park
Just putting new shoes on the back and when the drum is free , and you spin it. It goes tight then slack then tight again why is this, and its worse on one side than the other? Cheers
http://www.Zeemax.com
adjust the shoes fully up tight then get a hammer and bash the drum to centralise the shoes adjust till the catching just goes after 50 mile re adjust
Zeemax Power
Member #: 393
Oulton Park
cheers
You can also centralise the shoes by pressing the brake pedal a few times.
a hammer is more fun though
Zeemax Power
Member #: 393
Oulton Park
no realised now the hubs bent or the shaft going to run it and see if it frees up
try putting 2 wheel nuts on diagonally with some form of spacers to pull the drum tight against the hub.
Also check theres not any crap on the drum to hum matting flanges.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
Mine does the same but I think I have a few high spots on inside of the drum. I have to run the adjusters backed off to clear the high spots so I have no handbrake and a long pedal. New drums on order!
On 7th Nov, 2008 Nic said:
naeJ
m
Zeemax Power
Member #: 393
Oulton Park
Both drums now seem to be locked on and hard to turn with a bar is there a way to adjust them inside or has something gone cheers
stefaz
Member #: 1656
stoke-on-trent
adjuster on the back of the drum mate
are they adjusted correctly?
try slackening them off with the adjuster on the back
if in the past someone has left the car parked up for a prolonged period of time with the handbrake hard on, it can sometimes press the drums oval, but i doubt this is whats happening here
