| Home > Help Needed / General Tech Chat > Block heights.. | |||||||
3 Posts Member #: 1893 Junior Member |
20th Aug, 2007 at 08:09:48pm
Hi all, first message here in what appears to be an excellent forum..
20th Aug, 2007 at 08:23:47pm
not possible as the crank Journals are smaller on the 998 engines
20th Aug, 2007 at 08:52:00pm
oh - maybe I didn't read this correctly when you PM'd me - I only saw the bit about block heights!
20th Aug, 2007 at 10:19:07pm
However, I do have a Midget block (1275) which is converted to Mini. For you clerver people out there, Midgets were delivered with 1100 )I think) engines with 2" journals. That means I can fit an S crank in my 998 block and make a bullitproof small bore bottom end.
20th Aug, 2007 at 10:29:53pm
There is a way round the journal size difference but its probibly just as expensive as a decent 1071 crank, I have researched this, its not worth the bother unless 998 cranks are the only ones left in decent condition, and thankfully, that point in time is several decades off yet Edited by Sprocket on 20th Aug, 2007. On 26th Oct, 2004 TurboDave16v said:
21st Aug, 2007 at 09:34:48pm
Thanks for the responses guys.
