Home > Show Us Yours! > Jim, we're famous
giallofly
Member #: 164
The Stig..
Newport Pagnell
http://www.youtube.com/watch?v=s8clv5Cja_c
I got a sh*t start!!!!
JF
The yellow sisters!
Mine is popping well between gear changes
Quality, I missed this race over the weekend. :)
Jason G
Member #: 1459
En-suite user
Braintree, Essex
It was top quality. Only .1 innit! A gnats!
On 19th Jan, 2010 wil_h said:
On 22nd of Aug, 2007 at 10:11pm Jimster said:
The yellow sisters!
Is that ALS or shift cut, Jim?
External wastegate ??
nice vid, yes wasn't the best start jon, Jim yours looked much better.
shane
Member #: 1246
Lowestoft, Suffolk.
You can just about make out me stood the other side of the track lol!! from where i was None of the cars looked pretty fast as they had all reached top speed by the time they came past, its nice to see the starts of the race, it shows what these cars can do!
Shane.
External wastgate and running a bit on the rich side caused the banging. My 60ft time there was still about 2.6 sec
Here is the timing slip from this run. I was C15, you can see that Jon's 60ft time is much better than mine, guessing that Jon running slicks (even though old ones) helped him here.
slicks, old but have there uses,
carl
Arnt you running a lot more power than jon tho, not going to help you set off?
giallofly
Member #: 164
The Stig..
Newport Pagnell
Those slicks are shot, even after a realy long smokey burn out they barely gripped, I had forgot I had a set of Miglia rears on 6x10 minilights, they would have been better.
You can see Jims, extra power and taylored ECU'd midrange doing it's stuff.
Given my quickest is 13.074 @108 I was doing crap.
The day before I had dial in more than i needed of toe out up front, this made the car hard to push in a straight line, I am sure this affected the times.
I must have a look at that and get the old girl back out this year to attempt to joint the sub 13 club!
JF
Ric
Member #: 36
Basingstoke
are you still running a dizzy on your car jon? Would be a very impressive achievement to get sub 13s from it :)
Dizzy and carbs rock!
