Home > General Chat > OT Gas regulating body
whos the regulating body over gas companies? in the way that offcom is the regulating body over telecommunications
andeh
Member #: 97
Near Daventry, midlands
the useless bunch known as ofgem
Edited by andeh on 23rd Aug, 2007.
cool cheers
i tried to make a complaint to british gas after i called an engineer out to fix a leak and he never turned up, i run customer services and asked for the complaints procidure the girl said she did not know when i asked for a manager she told me she was terminating the call
ive now done 3 calls to them and i might as well stab myself in the head it would be less painfull
Turbo Shed
Member #: 30
Epsom, Surrey
British Gas is owned by centrica who i did a bit of work for not so long ago. people still think that if you have a problem they are the people to call. this is wrong! British gas engineers can only do the same as any Corgi registered plumber but charge alot more. if your problem is before the gas meter you need to call Transco, otherwise any Corgi registered plumber.
British Gas are utterly useless wankers, unfortunately so are N Power, Yorkshire Electric, PowerGEN, and any of the other showers of buffoons I have had the misfortune to attempt to deal with.
here here,!!!!!
wolfie, do you want me to fix the leak for you??
Do you need to borrow my pikey boots Jim???!!! *happy*
Turbo Shed
Member #: 30
Epsom, Surrey
dont forget to use a lit match to locate the leak
confusednewowner
Member #: 854
Fareham, Hampshire
You may well joke but I overheard some guy in B&Q saying that about the gas fire he was about to install!
Also agree about BG being wankers.
In actual fact it is perfectly legal to do gas installation work in your own home as long as you are competant to do so. How you define "competant to do so" I've no idea.
stefaz
Member #: 1656
stoke-on-trent
pair of hands with opposible thumbs??
andeh
Member #: 97
if you have a gas leak and are concerned you can always call the gas escape number 0800 999 111 (or was it 111 999)
mine was a warrenty job
