| Home > General Chat > it's meant to be a new Straight cut box ? | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
23rd Aug, 2007 at 12:31:57pm
Hi lads.
Shit Happen's |
23rd Aug, 2007 at 12:46:17pm
Can you take some pics of the box (more importantly the damaged gears) you've recieved?
23rd Aug, 2007 at 12:51:02pm
The auction suggests the gearset is new, but the wording is such that it is open to interpretation.
Edited by joeybaby83 on 23rd Aug, 2007. "Turbo's make torque, and torque makes fun"
23rd Aug, 2007 at 12:52:23pm
Give them a call to see where you stand. I think you can get refund via paypal as item is not as described, if all else fails. On 19th Jan, 2010 wil_h said:
23rd Aug, 2007 at 12:58:19pm
Yeah it doesn't actually say new gears just newly rebuilt! If you did ask if they were new over the phone then they should be. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
23rd Aug, 2007 at 01:28:53pm
Well i called them up, and they were fine about it. said i was the first person with this problem Shit Happen's |
23rd Aug, 2007 at 01:33:46pm
Thats bloody cheap then for new gears!! did they say what gearset they were using?
23rd Aug, 2007 at 01:33:51pm
hes obviously using the ms clubman set that reuses the old 1st gear
23rd Aug, 2007 at 02:16:00pm
On 23rd of Aug, 2007 at 01:33pm matty said:
Thats bloody cheap then for new gears!! did they say what gearset they were using? Did you get a cross pin diff aswell? I just phoned them again to ask, and he dont know.. his boss gets them in, but his on holiday at the mo. i got a standard diff with it. But ive got my own 4 pin diff from Min-its :) just need drop gears now. Shit Happen's |
23rd Aug, 2007 at 02:21:34pm
On 23rd of Aug, 2007 at 01:33pm joeybaby83 said:
hes obviously using the ms clubman set that reuses the old 1st gear Could well be.. I would keep it, but he said he will get me a new one built up. so that keeps my mind at ease. I wans't gonna go for a straight cut. but the guy i know, hes mate has one, and it wasnt as loud as i thought it would be. plus now ill be able to give it bit more stick now and then
Do i go for a 1.1 drop gears ? Cheers.. Shit Happen's |
23rd Aug, 2007 at 04:53:42pm
So is it still ok to use the clubman set that reuses the old 1st gear ?
Shit Happen's |
23rd Aug, 2007 at 05:07:20pm
Yes its fine.
30th Aug, 2007 at 05:20:48pm
Update.
Shit Happen's |
30th Aug, 2007 at 05:32:32pm
i personally wouldnt send any of my bits over to this company, god knows if they would make it into another box
30th Aug, 2007 at 06:30:30pm
Linky:
On 30th of Aug, 2007 at 05:20pm Mini_Uk said:
Update. he said there all old bearings which are better then the new ones?? I think he meant 'cheaper' not 'better' !!! Either way - So you paid 260 for a SC box, that looks like its not even been cleaned, save for a stint at the jetwash at the local petrol station? The MS gears alone are that much alone aren't they? You're not going to get 120+ quids worth of new bearings and labour thrown in. Strikes me, you should withdraw from the auction (have you already paid?) and sort this out yourself via the reccomended folks on here. Or, get it, and then strip it down yourself and swap bearings out. This should also allow you to clean the casing, and inspect the quality of the (!) workmanship that you've just paid for. Edited by turbodave16v on 30th Aug, 2007. On 17th Nov, 2014 Tom Fenton said:
30th Aug, 2007 at 06:35:09pm
I would get them to rebuild it, just so you get the new undamaged gears then get someone to check it over and fit anything that hasn't been replaced that should of been e.g bearings.
Edited by matty on 30th Aug, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
![]() 725 Posts Member #: 177 Avon Park 2006 Class D Winner Woburn Sands |
30th Aug, 2007 at 09:00:01pm
look at the the colour of the box its self! when I rebuild boxes i allways dip the boxes in acid to remove the horrible black gunge.
16V project underway |
30th Aug, 2007 at 09:37:31pm
old bearings are better than new ones hhhhmmmm
30th Aug, 2007 at 09:51:08pm
Just found out that An old friend of a friend does mini's for a living. and he said he would build the box up for me. so what i was going to do, is tell the guy to send me the gears, as well as the diff and free crownwheel & pinion it comes with Shit Happen's |
30th Aug, 2007 at 10:30:50pm
P.s. there meant to be timkin straight cut gear set.
Shit Happen's |
![]() 1252 Posts Member #: 1656 Post Whore stoke-on-trent |
30th Aug, 2007 at 10:49:24pm
after chatting to benross yesterday he assured me that the timkin drops are the ones to go for Edited by stefaz on 30th Aug, 2007. On 23rd Oct, 2009 sim_ou_nao said:
eu gosto de mamas = i like boobs |
30th Aug, 2007 at 11:14:18pm
the gears are Trannex gear set i think he said... Shit Happen's |
. he said sorry etc, were build u another one, or have a refund. he said they get the straight cut gearing new, and someone else builds them with new bearing etc. so why has some of the gears got pits on the edges i said? maybe a bad batch he said
he then said, 1st gear might be a good 2nd hand gear??
