| Home > Help Needed / General Tech Chat > Can't start, won't start | |||||||
24th Aug, 2007 at 07:39:51pm
Does anyone know where the inhibitor switch is on a 998 auto?, the reason i ask is i tried to turn the engine over on my turbo with the key and i get nothing at all. I'm sure all the wires are in place and in the right place, i'm assuming the original inhibitor switch may be the cause. I just need to know its whereabouts so i can join the wires together.
133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
24th Aug, 2007 at 07:48:56pm
In the old gear selector mech.
24th Aug, 2007 at 07:52:18pm
Ah, I dont have that anymore, will there be wires that used to go to the selector? like near the reverse switch?
24th Aug, 2007 at 07:59:47pm
On 24th of Aug, 2007 at 07:52pm chinlesswonder said:
, will there be wires that used to go to the selector? I've no idea, go and look.
24th Aug, 2007 at 08:27:42pm
already have, non in the car or underneath in the tunnel, would an inhibitor stop an engine turning over or just cut power to the ignition coil to stop it firing. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
24th Aug, 2007 at 08:35:54pm
From vaguely looking at a wiring diagram some years ago I've a feeling it interrupts the signal wire from the ign barrel to the solenoid.
24th Aug, 2007 at 08:40:12pm
thank you Tom. 133.5 bhp 123 lb torque 116mph @6640rpm 9.5psi
24th Aug, 2007 at 08:47:13pm
Found the wiring for the inhibitor, behind the dash, joined them together and it now cranks for oil pressure.
