| Home > Help Needed / General Tech Chat > A few questions about running in | |||||||
108 Posts Member #: 654 Advanced Member |
25th Aug, 2007 at 10:15:22am
Hi im currently at the stage of running my engine in, its pretty standard with a kent 266 and an rs intercooler, I just wondered what my timing should be as im going to strobe it up to run the cam in, should it be 8 degree's? also my fuel pressure is 3 psi, and this should be around 4 I think, which way do I turn the screw on the regulator to up this pressure, and is it overly sensitive, and one last question, I have only run my enigne breifly to check for leaks etc but alot of smoke was coming out of the exhaust, is this normal after a total rebuild?
25th Aug, 2007 at 02:53:51pm
3 psi fuel pressure is OK really, 3.5 psi maybe better. Turn adjuster clockwise to increase, in any case you need a gauge on while doing any adjustment to get it set right.
27th Aug, 2007 at 04:34:53pm
thanks tom, the smokes clearing up nicely now any way, cheers |
27th Aug, 2007 at 05:24:55pm
Please read this Kav............... http://www.mototuneusa.com/break_in_secrets.htm
27th Aug, 2007 at 05:40:44pm
Yer, I read that before benross when I was searching on here, has it been proven tho, its probably right but I cant afford to run my engine in wrong, is that method not more beneficial from modern engines with "tighter" clearances?
27th Aug, 2007 at 06:03:44pm
all my motors follow the same break in as this and they run well no problems todate
27th Aug, 2007 at 06:32:32pm
Go give it a good thrashing! On 26th Oct, 2004 TurboDave16v said:
27th Aug, 2007 at 06:57:30pm
why is my right ankle twitching now ive read these posts?
27th Aug, 2007 at 07:58:54pm
The trick is to keep cycling the load .... screaming the guts off it for minutes at a time won't be doing what you want. Follow the instructions and as Steve says .... no trouble.
Edited by RogerM on 27th Aug, 2007. Every day is a school day ...........
27th Aug, 2007 at 10:00:06pm
Hmmm, interesting, thing I'll give it a go then, so will the boost not be a problem for running in, bearing in mind I have a closed off bleed valve so I'll be limited to 4psi anyway. |
27th Aug, 2007 at 10:48:51pm
On 25th of Aug, 2007 at 10:15am kav said:
Hi im currently at the stage of running my engine in, its pretty standard with a kent 266 and an rs intercooler, I just wondered what my timing should be as im going to strobe it up to run the cam in, should it be 8 degree's? Cheers, Kav It should start and run at 8 degees,I have a 276 in mine and its on 16 degrees,so you may need 10 or 12 8 degrees is only for the std cam Edited by Dangerous on 27th Aug, 2007.
![]() 539 Posts Member #: 6807 Post Whore York |
25th Jun, 2010 at 01:15:09am
sorry to resurect an old thread but what about running the cam in for 20 mins at idle that i have heard mentioned many times?
25th Jun, 2010 at 06:54:34am
Dont run a new cam at idle. It needs 2-3,000 revs to fling plenty of oil around while it wears away any micro-high spots left by machining. I seriously doubt it! |
