| Home > Help Needed / General Tech Chat > Nut thread for switch carrier | |||||||
28th Aug, 2007 at 10:52:44pm
I have lost one of the nuts that holds the the "switch carrier" in the dash, you know the bit that has the choke and the heater pull as well (the nut that holds the braket to the car that is). Does anyone know the thread of it by chance? Every time I pull the choke the whole thing comes out!
On 7th Nov, 2008 Nic said:
29th Aug, 2007 at 12:01:50pm
I'm sure I've successfully used M5 there in the past.
29th Aug, 2007 at 12:50:54pm
i wouldnt have thought it would be metric, more like 1/4 unf? maybe smaller? "Turbo's make torque, and torque makes fun"
![]() 695 Posts Member #: 984 Post Whore Westhoughton, Bolton |
29th Aug, 2007 at 12:54:21pm
Jay, i may have one spare, shall check at the weekend if you cant get one. |
29th Aug, 2007 at 01:14:43pm
M5 does work, just checked. Probably imperial though.
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
29th Aug, 2007 at 09:04:55pm
if an m5 fits, then it will probably be a 10/32 or 10 unf thread. I made the mistake at work of doing that. It depends on the age of mini as i know some are half metrificated! |
30th Aug, 2007 at 07:50:22am
Oh M5 great! I'll hunt around my local nut factors and failing that I may take up your offer Jackman! I was too lazy to take out the other nut to check it out. That's sad isn't it? Thanks guys! On 7th Nov, 2008 Nic said:
