Home > Help Needed / General Tech Chat > wheels and tyres query
i have cooper alloys (pic below) i was wondering if it safe to run 165 tyres on this width rim, i know having to wide a tyre can cause problems eg beading of the tyre popping off under heavy cornering i was wondering if the yoko A539 165/60 R12 tyres i have will be safe to use on them.
yours paul
No problem.
We run 165/60/12 Falkens on the standard Rover minilites on three of our minis.
Might rub the arch a bit at the front with standard or bent tie bars.
Edited by Paul S on 29th Aug, 2007.
thanks very much mate :) cant wait to get them on now *happy* just need to sorth out the tracking first so i dont rub on anything. what pressure do you recomend running (what do you run) i was thinking about 32psi but i dont know if that is to high/low
cheers paul
I run them at 30 psi, but I've never tried anything else.
They'll be fine as Axel says, I've previously ran them on the standard Rover Cooper 12" alloys, (4.5 x 12 IIRC).
In fact as well as being fine they'll make the car handle loads better too, go for it!
ill give it a try at 30psi see how it feels. i ran the 145/70's at 33 so ill have a play about with the pressures
32 psi sounds high, try 28 psi see how you get on.
I hesitated to say that mine sticks to the road like glue in case the 10" Policeman had a go.
However, it has got fully ajustable suspension and was properly set up by Scruffy which makes all the difference IMO.
LOL.
You'd have to be careful Paul, as both the 10" and 13" policemen could book you for having 12's!!!!!!!!!!!!
i have gay-max shocks and adjustable tie bars and bottem arms. going to be running kyb self adjusting shocks soon :) so i probaly wont handel as well as yours
I'm using the KYBs all round.
How about some rear camber and tracking brackets?
LOL.
Maybe I should take up the role of 12" Policeman.
I was going to convert to 10s but I'm about to blow the budget on an Innovate LM1, so they will have to wait.
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
Just checked some old dealer info I have from about '91 and the quoted pressure for 165/60/12s on the 4.5" rim is 28psi front and rear.
MPi manual says 28psi front and rear also
Guess that makes 28psi a good starting point ... you can always play with tyre pressure when you get used to the car.
LOL I run my A048s on the sportspack rims at 20psi *tongue*
Have run down to 10 psi in the DON....
Turbo Tel
Member #: 588
Delaware, USA
my 12"with Faulkens are slightly rubbing would adjustable tie bars fix that or should I shim the front mounts??
Terry
Edited by Turbo Tel on 29th Aug, 2007.
Mine rub a bit under certain conditions, like 4 up going to MITP, but the only way to stop it would be to compromise the settings, so I live with it.
Turbo Tel
Member #: 588
Delaware, USA
OK
I'll try a few shims first, and then wait and see what happens when I go to neg camber arms and adj tie bars over the winter..
Terry
You could always try a big hammer.
Mines a bit too low if anything.
Mini_Andy
Member #: 432
i have some group A adjustable tie bars, 1.5 deg neg cambers bottom arms (fixed) and rear tracking kits sat aroud, same as this :
http://www.minisport.com/classic-mini-shop...it-product.html
£50 if your interested....
Terry
Adjusting the tibars to achieve clearance is not a good idea. Tibar length adjusts the caster, which should be set regardless of whether the tyres foul or not.
The only way to make sure that the tyres clear the body is to modify the wings where it catches (or buy and fit sportspack wings)
Turbo Tel
Member #: 588
Delaware, USA
On 29th of Aug, 2007 at 09:07pm Turbo Tel said:
OK
Terry
OK on the castor, What I meant is once I have adjusted it properly with the adjustable tie rods lets see if it still rubs. Its looks like the right side wheel is further forward in the wheel well so thats why I was asking. Of course as I replaced all the front metalwork, I could have got it slightly wrong..
Last night I loosened the front mountings and shimmed them, also jacked up the bodywork as I tightened and its a little better.
Thanks Miniturboman, but I'm not quite ready yet and the postage to USA can be a problem...
Tel you should have his arm off, £50 is an absolute bargain.
Turbo Tel
Member #: 588
Delaware, USA
Absolutely agree It is but...
http://www.minispares.com/Product.aspx?pid=38461
No VAT, adjustable lower arms and they are wonderfully cheap on the shipping to USA... And If I am buying other stuff (as I will be) shipping gets even better Also my credit card has been SPANKED with the engine rebuild, it needs a rest!!
im running 31psi all arround atm, its what i find the best for the car its handaling amazingly, i feel it handels better than with 28psi but then its personal choice. i have only slight rubbing issues with the tyres on the arch when turning left sharply but i have a badly formed arch so never mind :) cheers for all the help i will get some pics up soon with them on :)
