Home > Help Needed / General Tech Chat > thermostat
sauber 200
Member #: 245
what temp thermostat is everyone using?
cheers
giallofly
Member #: 164
The Stig..
Newport Pagnell
I use a 76. Keeps cool unless you cane it for a long time.
1380Turboman
Member #: 221
Personally I dont use a thermostat, but instead have fitted the proper blanking cup u can get from minispares. This insures proper flow of water to all chambers.
PC
i always use a 80 i think it is, keeps everything spot on even in the hot weather, has had some bypass holes drilled in it though.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I use a blanking plate...
Always have done on performance minis!
alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
a blanking plate?..what's that?
clubman_dan
Member #: 142
Winchester
Removal of the thermostat helps to reduce engine temperature, however a thermostat blanking sleeve should be fitted to maintain correct coolant circulation to the entire head. Failure to do so will cause overheating around #3 and 4 combustion chambers-with obviously disasterous results. When the blanking sleeve is used, it is also necessary to blank off the by-pass hose (not found on late heads) between the head and water pump.
all that comes from minispares website
DAN :)
1380Turboman
Member #: 221
Yip thats the blanking cup i use!
giallofly
Member #: 164
The Stig..
Newport Pagnell
Well aware of a blanking sleeve, alex's plate?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Similar...
well ok exactly the same LOL
Sleeve then :)
Alex
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
got ya!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Not hard to do :)
Alex
AlexF
88 degree one at the mo, & it stiil runs very cool .... lol
Though i suspect it will be a bit different when i start running more boost.
Phil. *smiley*
74 at the mo.
74 all the time...
(with the three 5mm holes in the rim for the bypass)
I've always had cooling problems, going to try a new rad, a std one I think,
