Home > Help Needed / General Tech Chat > Who can weld in my bolt in cage?
Is this even possible? if so, who fancies the job? I would also like a diagonal welded in the rear, as it doesnt currently have one.
The cage is a Rollcenter 6 point bolt in jobby
-a.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I would weld a bolt in cage in.... its not desgined to be welded!
There is a difference in the design apperently....
Ring rollcentre and ask, they are a very helpful :)
Alex
AlexF
Ok then, who can weld in the thick plates that they bolt on to?
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Normally those thick plates are "washers" that fit the other side of the floor pan to the feet....
again ask rollcentre :)
I added patches as well to mine, but then again mines going racing one day!
Alex
AlexF
you want 3mm thick plates do a la frog to make it a proper job.
Washers arent really worth doing i'd say!
if it was round here id recommended the same bloke as he does a neat job.
yeah, they were nicely done. dont know anyone down here though
Alex
lol one day!!!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I knew you'd pick up on that Jim!
Alex... when do you need it doing?
Alex
AlexF
dunno, next month or so I suppose.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I can probably help you out with that :)
AlexF
cool cool, able to do it at mine? (saves me having to get the car over to yours in bits!)
Ric
Member #: 36
Basingstoke
as far as i'm aware, you won't need to weld those plates on, bolting them through the cage>body>plate should be fine. I think they are just there for load spreading.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
It depends if Alex wants to race it or not...
alex
AlexF
no races, but trackdays, so i dont want to die please.
if you get it rolling ill sort it out
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
In the past I have bonded the plates on with stikaflex to stop them moving if you have to unbolt the cage and also stop the water getting between them and the shell.
Most of the bolt in cages can be fitted with the spreader plates bolted up from the outside.
Edited by RogerM on 3rd Sep, 2007.
Ollie
Member #: 1380
you will have 2 lots to do then *wink*
On 3rd of Sep, 2007 at 07:10pm RogerM said:
In the past I have bonded them on with stikaflex to stop them moving
I hope you used some bolts as well.
I reckon my cage will fail scrutineering, if you stick it in with stikaflex.
Edited by Rob H on 3rd Sep, 2007.
RogerM
Member #: 1217
Edited my original post just in case some pedantic government type comes along and pointed out an extra word might help avoid confusion!
