| Home > Help Needed / General Tech Chat > valve springs | |||||||
173 Posts Member #: 873 Advanced Member Thatcham, berkshire |
7th Sep, 2007 at 06:33:54pm
after having problems with my car reving in 3rd and 4th under load ive changed many things to with fueling and have checked timing numerous times on the laptop.
7th Sep, 2007 at 06:51:38pm
i doubt that this is the problem but.......... the spring will be tired though
7th Sep, 2007 at 07:10:34pm
thanks for the reply mate. really am stuck on what it could be the valve springs were an educated guess.
7th Sep, 2007 at 10:51:22pm
Run the symptoms by us again...
Edited by Turbo Tel on 8th Sep, 2007. website:- http://www.terryhunt.co.uk
8th Sep, 2007 at 06:22:18am
If the valve springs were knackered it would only rev to a certain point no matter what gear it was in.
8th Sep, 2007 at 10:54:03am
Have you done a compression test? Sounds like the same symptoms I had when my cam lobe had worn. Edited by matty on 8th Sep, 2007. https://www.facebook.com/pages/Fusion-Fabri..._homepage_panel
8th Sep, 2007 at 01:10:06pm
ok this is what is happening. the car runs well in 1st and 2nd gear right up to 6.5k not that i would wish to push it this far all the time but it does pull that fair, 3rd gear will go to about 5.5k and just stop accelerating and will just sit their and hold back. 4th gear will get to about 4 to 4.5 k and do the same as in 3rd gear.
8th Sep, 2007 at 05:43:30pm
On 8th of Sep, 2007 at 01:10pm mattyking said:
how do i check all of these the lap top reads well and advances with the table as it should do. 1st and second being Ok makes no sense.. you sure theres NO symptoms in 1st and second?? Do you have a AFR meter? To check the ign. timing first unplug the megajolt box and check your timing with a light, it should sit at 10 degrees. Plug it back in and rev the engine up and down a bit and using the timing light make sure it advances properly i.e. check it at 4000 rpm you should see it advance to whatever the MJ says it should be. you may want to make a test map so that all advances are the same regardless of vaccume/boost. For real driving Above 3500rpm the engine should see about 34 degrees at atmospheric (100 on ther Mj) and 46 degrees at full vacuume (about 20 on the Mj) maybe you are way out with the timing before the engine gets into boost so it just cant make it there?? can you post the map?? The only thing I have noticed on fuelling is that higher gears are always a bit leaner than lower gears, My theory is that the oil in the dashpot enrichens the mixture less in 4th because the dashpot piston is not moving as fast but I can't see that causing this much grief and you should be able to sneak up on the high revs anyway but try some thick oil in the dashpot, 80 wt gear oil?? That leaves you with Valve timing, you can do a rough check with the engine in place but doing it properly and detecting a bad lobe is probably engine out job. Was this engine just rebuilt?? could the valve timing be set wrong? website:- http://www.terryhunt.co.uk
8th Sep, 2007 at 07:18:15pm
When you do a compression test all the cylinders should be equal.
8th Sep, 2007 at 07:53:29pm
thanks turbo tel ill check the megajolt tomorrow i would post it up but ive always had trouble with it like before could i email you it instead is that ok? as for 1st and 2nd im sure it pulls just fine it doesnt feel like im getting any porblems with it however it doesnt sit in the gears long enough does it but it does pull very well in 1st and 2nd.
8th Sep, 2007 at 08:05:04pm
On 8th of Sep, 2007 at 07:18pm matty said:
When you do a compression test all the cylinders should be equal. It does make a difference what gear your in with this problem as in first and second gear it doesn't take as much power/torque to get to the higher revs in the higher gears it does. Its worth checking as it sounds like you've tried everything else. But SOMETHING would be going on.... i.e it would feel down on power. Maybe you should re-install a distributor, that would eliminate the Mj then I would really start wondering if the cam was timed in correctly.. but yes, always good to do a compression check, expect around 180psi I think... You may get a clue as to the valve timing from that as well, plus if they are equal but down on pressure it may indicate that the valve timing is off. Edited by Turbo Tel on 8th Sep, 2007. website:- http://www.terryhunt.co.uk
8th Sep, 2007 at 08:14:49pm
i do not have a turbo dizzy any more so i cant try that unless i can use a standard 998 one which i dont think i can. is it possible for the edis componets to be dead or the whole mj unit as i bought this from a guy tried and tested. so i hoping that its the edis components. can i test these.
8th Sep, 2007 at 08:21:05pm
9th Sep, 2007 at 04:48:58pm
ok i have disconnected the mj and put the timing light on it it reads 10 degrees as it should do.
9th Sep, 2007 at 04:53:52pm
You didn't mention...
9th Sep, 2007 at 04:57:57pm
On 8th of Sep, 2007 at 08:14pm mattyking said:
i do not have a turbo dizzy any more so i cant try that unless i can use a standard 998 one You can still use the 998 one, Just disconnect the actuator arm from the turbo, it will be just like an a N/A and should rev all the way to 6000 if the Mj is the problem Terry website:- http://www.terryhunt.co.uk
9th Sep, 2007 at 08:18:11pm
sorry i could not try the advance again with the mj back in because i cannot get access to my lap top till tomorrow so will try the advance on lap top with the time gun tomorow.
9th Sep, 2007 at 08:51:46pm
You can at least check with a timing light that it advances at all... If theres something up with the Mj you will be running in limp mode and it will stay at 10 degrees, and that could cause the symptoms...
9th Sep, 2007 at 09:13:52pm
Has it always done this since you fitted the megajolt? Are you sure your coilpackis a good one and not a dud?
16th Sep, 2007 at 11:09:32am
update. i have disonected mj and it works fine in limp mode. plug it back in and it appears to be fine on the drive blipping the throttle the engine advances with it.
6th Oct, 2007 at 02:57:52pm
just letting you no i fitted new valve springs and believe it or not that seemed to fixed the problem. the old ones some of them you when fitted you could still push them down with fingers and some were shorter than others to due to wear i would guess
6th Oct, 2007 at 05:14:53pm
matty which springs did you fit ?
6th Oct, 2007 at 05:24:55pm
200 lb double valve springs |
6th Oct, 2007 at 11:07:24pm
Interesting....
