Home > Help Needed / General Tech Chat > Connecting Megajolt to my Pc
shane
Member #: 1246
Lowestoft, Suffolk.
I dont have a lap top so what lead will I need, is this suitable? http://cgi.ebay.co.uk/USB-TO-9-25-PIN-SERI...1QQcmdZViewItem
Or is there another I could use, attached is the rear of my pc.
Sorry for the stupid (and probably already asked) question, but couldnt find an answer in the search pages.
Shane
you should just be able to stick a 9pin -9pin cable into either of the sockets next to the 25 way,
I think this is a better way to do it as you normally need drivers for usb-9way cables, and they can be a bit fritzy.
the reason people use the usmb's is becaus modern laptops don't usually have the 9 way anymore.
shane
Member #: 1246
Lowestoft, Suffolk.
mega, thanks mini13, how readilly available are these cables? I take it by the looks of it its just a 9 pin male one end 9pin female tother?
Thanks again
Shane.
Cables easily available, look on ebay, serial cable.
NOTE: you do NOT want a NULL-MODEM cable, this looks the same but is wired differently.
shane
Member #: 1246
Lowestoft, Suffolk.
How about....
http://cgi.ebay.co.uk/Serial-Extension-2M-...1QQcmdZViewItem
Thanks Tom, top tip.
Shane
i think you need a female - female lead
http://cgi.ebay.co.uk/DB9-RS-232-F-F-SERIA...1QQcmdZViewItem
shane
Member #: 1246
Lowestoft, Suffolk.
The 9 pin on the back of my pc needs a female to fit it (is this odd?), but the 25pin needs a male, hense me thinking i needed a male female, please correct me if im being a tw*t tho, been making classic school boy errors all day!
Shane.
Mike
Member #: 107
Sunny Sussex
yup, you just need a 9 pin female to female cable, as said above a 9 to 9 serial cable as a common as muck and dead cheap. The ebay link above is what you need, although 5 metres is a bit of an overkill, unless you want to run the cable from indoors to the garage!
shane
Member #: 1246
Lowestoft, Suffolk.
Female to female 9pin wont fit? Am I missing something here? These are 9pin plugs I want to connect.
Shane
Ollie
Member #: 1380
http://cgi.ebay.co.uk/New-9pin-DB9-M-F-RS2...1QQcmdZViewItem
shane
Member #: 1246
Lowestoft, Suffolk.
Top banana Ollie, thanks for that, much appreciated.
Shane.
Mike
Member #: 107
Sunny Sussex
sorry, my bad - I should read my text b4 posting. I was looking at the female connector on the MJ, doh
shane
Member #: 1246
Lowestoft, Suffolk.
Lol not a problem fella, was just scratching my head thinking I had missed something really obvious.
Cheers again
Shane.
Jay#2
Member #: 648
Northern Ireland (ex AUS)
I know your just using your 9 pin on your PC but if that fails I used this:
http://cgi.ebay.co.uk/USB-to-9-Pin-Serial-...1QQcmdZViewItem
...to go from USB to the MJ unit with no probs what so ever (once I installed the driver that is*blush*).
On 7th Nov, 2008 Nic said:
naeJ
m
shane
Member #: 1246
Lowestoft, Suffolk.
Thanks jay, may end up purchasing one of these to, as im pretty sure my mates lap top im going to borrow when I finally get to the rollers doesnt have a 9pin port.
Shane.
shane
Member #: 1246
Lowestoft, Suffolk.
My lead arrived, have installed the software I believe I need (V3.0.o), but having problems
When MJ is plugged in should I be able to find it in hardware connected? Because I cant! Am I missing somthing obvious? Have re read mj posts and loads of stuff on the picasso site, and im even more confused. If anything this has highlighted ho comuter ilitterate I really am!
Any suggestions?
Shane.
shane
Member #: 1246
Lowestoft, Suffolk.
I think I have solved it, am I right in thinking, that if im sat here with the megajolt only connected to my pc via the serial lead, it wont work, as I need to provide a power supply? If this is the case, please form an ordilly que to hurl insults at me!
Shane.
colas
Member #: 102
Pennsylvania USA
Yes you need to power it. If I remember a 9 volt battery will power it enough. Correct me if i'm wrong.
Jay#2
Member #: 648
Yes I think others have used a 9v, can't coment though as I had it in the mini before I connected to the laptop.
naeJ
m
A 9 volt battery powered my megasquirt up, dunno how long it'll last for though.
shane
Member #: 1246
Lowestoft, Suffolk.
The 9v battery worked a treat! GOD IM A NUMPTY!
Shane.
