| Home > Help Needed / General Tech Chat > what temp should it run at? | |||||||
![]() 192 Posts Member #: 837 Advanced Member rugby |
8th Sep, 2007 at 05:41:56pm
I think my mini may be runing a little hot,
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
8th Sep, 2007 at 05:46:58pm
I think i have an 82degree stat fitted, two core rad, no bypass hose but 1/8" holes drilled in the thermostat to aid a little flow through while its closed, I think to run without a stat you need a coller "insert" for the head (fits in thermostat housing/head) with hole drilled the correct size to run without a 'stat.
Edited by shane on 8th Sep, 2007. |
8th Sep, 2007 at 05:53:04pm
the std gauges can be a bit misleading,
Edited by Joe C on 8th Sep, 2007. On 28th Aug, 2011 Kean said:
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
8th Sep, 2007 at 05:57:42pm
A blanking sleeve should be put in the place of the thermostat and 80s sounds about right for temp.
Back once again like a renegade master |
8th Sep, 2007 at 05:59:11pm
yep..mine runs in the 80's On 19th Jan, 2010 wil_h said:
8th Sep, 2007 at 06:27:42pm
i put a tempriture sticker on the head at number 4 which records the highest temp it gets, it hits 110
8th Sep, 2007 at 06:55:01pm
Even tho the engine has been rebuilt still excersise caution, turbohogster has had no end of trouble recently with a fresh built engine, it resulted in piston failure, it never hurts to double check things, I have found in the past complacency can be costly.
8th Sep, 2007 at 06:56:57pm
use a 74 deg stat with the holes drilled as mentioned
8th Sep, 2007 at 08:35:31pm
4 blade fan is less efficient than the standard plastic one in my experience. Also really noisy in comparison!! Every day is a school day ...........
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
8th Sep, 2007 at 10:17:27pm
Never go on the std guages they are terrible, the fact that its heating up quickly shows that the thermostat is doing its job. What you need to be looking for is a quick warmup, desirable, followed by a steady water temperature. I've seen the future and tbh its Pie
9th Sep, 2007 at 10:10:01am
ok then cheers guys
