Home > For Sale > FS: My 1979 'John Deere' Mini
slater
Member #: 1291
Suffolk / Birmingham
Unfortunately the time has come to say good bye to this one
For Sale: Fully rebuilt, fast road / track day / sprint / generally cool looking mini
A lot of you will know the story behind this car but for those of you that don’t I will fill you in
I bought the car in 2003 and over a period of about 3 years it was totally rebuilt using new parts throughout and many 1 off parts where necessary. The car was completed in June 2006 and after attending a few shows was featured in Mini Magazine January 2007 issue. The car was retired over the winter to fix a few teething troubles and was put back on the road in April. Since then I have only done a few hundred miles in it and that leaves the mileage at a miniscule 900miles since a full rebuild! It has been fully run-in and rolling roaded showing a strong 65bhp from the 1100cc engine but I don’t really get a chance to use it so I have decided to sell to make way for some new projects
I think the pictures speak for them selves; the car is in extremely good condition and has cost me £1000s and 100s of hour’s hard work! Although it has a few minor issues still to iron out it could be put into use straight away!
The car is crammed full of one off fabrication and parts, the most obvious being the wheels that I made myself and I have received offers of over £1000 alone!
Minor bad points include
• Tyres need replacing
• Rear shocks bottom out over large bumps (this can be fixed by fitting shorter shocks from a metro, available from GAZ for just £50 each!!)
• The roof has some slight scratches and chips to the paint where a roof rack was fitted but it would not take much work to put them right.
The car is MOT’d until June 2008 and taxed until October 2007
Price: £6750ono
Full Spec
Body
• 1977 mini 1000 shell
• Full weld in multipoint cage
• Steel ‘flip’ front
• Glass fibre ‘miglia’ arches
• ‘Tubbed’ rear inner arches
• Yellow ‘John Deere’ Stripe (removable vinyl)
• Polycarbonate side and rear windows with sliders
• New stainless bumpers
• All new chrome mk1 grille/ light surrounds
Engine
• 1098cc block bored +060”
• Fully lightened and balanced crank (wedged, knife edged, balanced, tufftrided etc.)
• Fully lightened and balanced con-rods
• Flat top ‘Powermax’ pistons
• Cooper 12G295 head, fully ported with big valves
• Kent 276 profile cam
• Lightened duplex timing chain
• Cooper free flow manifold and single box RC40 exhaust
• Minis spares alloy inlet manifold
• HIF44 carb with Piper cross foam filter
• Strengthened 1.3 ratio rockers
Transmission
• Close ratio ‘cooper/ 1275GT’ gear set
• Up rated diff-pin
• Up rated lay shaft
• Central oil pickup
• Orange clutch plate
• Lightened flywheel and pressure plate
• Gear linkage moved inside the car for ‘extreme’ race style short shift
Wheels and tyres
• 100% unique 10x7” split rims (using ‘MB/spectrum 3” and 4” rim sections)
• Stainless wheel bolts
• 165/70/10 Dunlop sport tyres
Brakes
• Front cooper 7.5” discs and calipers
• Green stuff pads
• Rear ‘minifin’ drums
• Brand new 0.7” master cylinder
• In car adjustable bias valve
• Internal routed brake lines
Suspension
• Strengthened sub frames
• Rebuilt rear radius arms
• Custom ‘hi-lows’ all round
• Adjustable front tie bars
• GAZ ‘short’ dampers all round
• 100% Poly bushed
Interior
• 2 Sparco ‘Rev’ race seats fitted on custom mounts
• 2 Sebelt 4-point harnesses
• Custom alloy dash
• TIM Voltage, oil pressure, oil temperature, water temperature gauges
• Digital Speedometer with data logging
• Astrali Steering wheel
• Alloy door ’cards’
Other
• 1off custom alloy fuel tank (31L capacity)
• Facet solid state fuel pump
• Filter king (smaller metal bowl type)
• Custom oil catch tank
• Mk2 Polo front mounted radiator
• Custom front brace bars
Viewing is very welcome, weekday evenings or weekends. More photos available on request. Any questions just ask! Or
Email: slaterspeed@gmail.com
Phone: Adam 07813469709
No time wasters please!
I work at the Norwegian company that imports John Deeres, so I really should have that sponsored...
Awesome looking mini.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Love that car, good luck with the sale...
JF.
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
Good luck mate
