Home > 998cc > 998 frenchy turbo project
tieeger
Member #: 1612
France
12g940 head from a MG metro sport
metro turbo cam
metro turbo exhaust and intake manifold
oil radiator
intercoller from vw golf gtd
water radiator from vw golf (gu)
electrik fan
additionnal electrik water pump from golf3 vr6
998 stock engine with flat top pistons
t3 from audi 2.5 v6 tdi
metro turbo gearbox and cluth
central oil pipe
this the spec of my building
i thinking put the exhaust valve of the metro turbo with the big inlet valve of the sport head
or pehaps put to a t2 turbo from a r5 gt
i will try to put some photos of my build
but if you have some advice ....
you post it
best regards tieeger from france to uk mini owners
Edited by AlexF2003 on 19th Sep, 2007.
My advice is bin the T3 from the audi, and use an R5 T2.
Looks good though.
alpa
Member #: 2093
Grenoble, France
Where in France ?
Are you searching for power ? If yes I'm not sure a diesel not water cooled turbo will survive, neither stock pistons. If not then 2.5 turbo could be too big.
If you have a front mounted radiator and an oil one do you really need an additional water pump (except for when you turn off engine on the track) ?
On my 998 NA A+ I have a front Metro radia and partially blocked water holes and the fan is hard to activate even on 35C hot days. With a 88C thermostat temperature stays at 75C all the time.
These are theoretical suggestions, I'm only starting my low boost Mini project.
The 2.5 V6 TDi Audi engines have a GT2052, a huge variable vane thing. I really think this is the wrong choice for a 998cc a series.
tieeger
Member #: 1612
France
thanks for advice i've changing my set up by this one:
T3 from the metro turbo in waiting get the T2 from the r5 gtt
standard metro sport head with 30cc chamber shape
1275 head gasket
metro turbo gearbox and cluth rebuild
central oil pipe
intercooler
metro turbo carb
dump valve install
10 psi set waste gate
standard 998 flat top n/a engine with undercrown oil cooled jet
and rwd engine with a front subframe with brake disk instalation
valant1
Member #: 1223
hi!
can you give me your msn adress please i make the same building
valant1
Member #: 1223
salut peut tu me passer ton adresse e-mail je compte faire le meme montage valant1@hotmail.fr
valant1
Member #: 1223
hi!
bon
hario
Member #: 2885
LMFAO wil_h
tieeger
Member #: 1612
France
sorry mini's addict for the long time i've not post reply since a long time
but i've bought a house and have a lot of work to done some f*****g stuff
anyway
my turbo project restart with a back cut of my mini in order to put a metty front drive train and engine with a turbo swap the T3 will be replace by a T15 from a R5 GT Turbo
the carb will be a suck throw system
the brake the mini system at back and the front metty system
tieeger
Member #: 1612
France
SOON SOME PICTURE OF MY MINI
