Home > For Sale > Fuel line 6 and 8mm, spark plugs + more - general automotive stuff
8 and 10mm id (13 and 15mm od respectively) fuel line ?2 a metre including the postage, capable of withstanding 10bar so fine for use *smiley*
also NGK BPR6ES plugs, ?8 a set of 4 posted
sump washers ?0.75 for 5
brake pipe, nuts, bolts, self tappers, o-ring kits, split pin kits, cutting and grinding discs, emery, wet and dry, electric terminals and wire etc, welding wire and other stuff.
All sorts of other things such as hylomar, copper grease, exhaust paste, valve grinding paste etc etc.
Just ask and i might be able to get you a good price.
*smiley*
jamesfawcett
Member #: 218
Bingley, West Yorkshire
three 90degree intercooler bends, as soon as you give me a price money will be in the post.
Price in the shop section mate *smiley*
But since you want 3 that will save you some money, ?41 for three posted.
I have to make a minimum order of ?100 so we should be ok at that. Ill see if B12 wants to order now as well. I want some bits.
The hoses are red, thats ok isnt it?
b12
Member #: 247
Kent/Surrey Borders
IaIn
DOnt wait for me matey ; I have a friend of a friend ( you know the score ) who may have some left over from one of his projects
I think it is 54 mm though .... I will wait and see what happens there first !!!
I have done everything to this bloody car but it is the InterCooler thats is stressing me the most for some reason !
I keep shying away from it !
S
TurboLessTosser
jamesfawcett
Member #: 218
red is better. Ill post you the money today if you want, how long do you think it will take?
Not too sure as ive never ordered from them before. Basically its the parent company of Samco so its top quality stuff.
Do you need any reducers? i was thinking of running a 90degree 46mm to 51mm elbow out the turbo so that the pipe becomes standard 2" size. the turbo outlet is 46mm.
Dont worry about the money till we've 100% got sorted what you want as it will make it easier. i trust you that if you say you want the stuff you'll have it.
