| Home > Help Needed / General Tech Chat > which main bearings to use? | |||||||
282 Posts Member #: 1404 Senior Member The Netherlands |
23rd Sep, 2007 at 08:47:50pm
Hello,
there is nothing wrong with a A-series that a turbo can't fix.
23rd Sep, 2007 at 08:56:23pm
You need a set of A+ main bearings to fit from 1985 onwards, this is when the smooth lower bearing shell became standard across the board, before this they were only fitted to A+ turbo motors, and the lesser engines had all grooved shells. You must have been supplied a set of earlier A+ or A series shell bearings.
23rd Sep, 2007 at 09:25:42pm
It's no problem to file a groove in the centre and fit the later bearings.
24th Sep, 2007 at 10:07:59pm
I will go for some new bearings. 1985 and onwards.
25th Sep, 2007 at 08:12:14am
There was an excellent discussion on the Minimania website concerning non grooved shells and cross drilled mains, but i cannot find it. It's said that to use the plain lower shells, you'll need cross drilled mains. This is obviously not true as no A+ crankshafts are cross drilled. It is however said that for out and out racing, the plain bearings are NOT the ones to use. On 13th Jul, 2012 Ben H said:
25th Sep, 2007 at 08:25:48am
I thought i red something in that line on minispares. But one grooved and one smooth is what came out off the block so i thinking off putting the same back in.
25th Sep, 2007 at 09:14:46am
Yes, use whatever that came out. It looks as for road engines the plain bottom ones work perfectly. I use both, but I'd go for the grooved ones in anything revving more than 6500rpms continuously. On 13th Jul, 2012 Ben H said:
25th Sep, 2007 at 09:39:39am
Vegards, Did anyone give a reason why the non grooved lower shell was not suitable for race use?
25th Sep, 2007 at 10:16:15am
Because the big end bearing would be starved for oil 180 degrees of crank rotation.
25th Sep, 2007 at 10:42:00pm
Actually you are more likely to maintain a good oil film on a plain shell than a grooved one. If you think about it what your hoping to do is maintain an even film thickness over the width of the shell under load. With a plain shell you'll have a pressure gradient, high in the centre - decreasing towards the edges. The groved shell will actually have a greater drop in pressure as it crosses the edge of the grove. Sharp edges are not good for smooth fluid transfer.
25th Sep, 2007 at 10:47:10pm
So How come BL engineers & D Vizard claimed it was much better in load bearing terms and yet above 6,500 rpm it's no good and likely to fail.
25th Sep, 2007 at 10:58:10pm
It starves the big ends!!!! Good for mains, rubbish for big ends. On 13th Jul, 2012 Ben H said:
25th Sep, 2007 at 11:05:10pm
Vergard, Penny has dropped, (english saying)
25th Sep, 2007 at 11:42:24pm
As Vegard says ....... the topic is regarding the mains and the loading between mains and big ends are different. Once you consider the interactions between all the areas it can look different again.
26th Sep, 2007 at 06:30:27am
On 25th of Sep, 2007 at 11:42pm RogerM said:
As a serious question how many people are taking their turbo'd motors above 6500 regularly? Absolutely. Hard Cut rev limter 9200rpm.
26th Sep, 2007 at 07:13:34am
Ok, fairy snuff but the Don uses a very specialist 4 valve engine.
26th Sep, 2007 at 07:25:11am
Why does it make a difference, it still uses the same crank rods and bearings.
26th Sep, 2007 at 12:52:29pm
Tom are you reving to 9k with standard A+ rods and a basically standard, i.e. no major work, crank? Very brave if you are. Every day is a school day ...........
26th Sep, 2007 at 12:59:10pm
They have had work, but the basic configuration is the same.
26th Sep, 2007 at 01:25:39pm
When I get home i'll post the loadings and peak piston speeds for that Tom! Edited by Joe C on 26th Sep, 2007. On 28th Aug, 2011 Kean said:
26th Sep, 2007 at 01:41:22pm
mini7 engine's used to get rev'd to 10,000rpm with standard rods, pistons and cranks (stress releived rods and crank). now they use omega pistons.
26th Sep, 2007 at 05:54:46pm
On 26th of Sep, 2007 at 01:25pm mini13 said:
When I get home i'll post the loadings and peak piston speeds for that Tom! Turds, no I won't the fre trial on the software i was playing with has run out.....
IIRC it was in the order of 4500g and 5000 ft/min. On 28th Aug, 2011 Kean said:
26th Sep, 2007 at 07:38:14pm
Another lesson learned...good topic On 19th Jan, 2010 wil_h said:
1391 Posts Member #: 1686 Post Whore Oxford |
6th Feb, 2008 at 09:34:45pm
indeed, i have been educated.
OMG Robert that's a big one |
