Home > General Chat > cams
What are people prefrence on camshafts what do you run?
Now here's a chance for some wildly different opinions to be aired.
I use a Kent 500 and love it. Fantastic low-down torque and early boost threshold.
I tried a Phase 2 and it made the car impossible to drive. So I sold it to Giallofly.
Wil
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Wil your car is a 998 thou isnt it?
btw mine is a std cam for the moment!
Alex
AlexF
Tis true it is a 998, but if I ever build a 1275 I would use the same cam. Admittedly, it might not work as well but I still like the idea of a very mild cam in a turbo
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
From the Kent Cams website it looks to me like the kent 500 is very similar to the mg metro profile... anyone got the excat std figures for 1275 and mg?
Kent 500
Cam Lift 6.67mm
Inlet timing 16/56
Exh timing 59/29
Inlet duration 252
Exh duration 268
AlexF
giallofly
Member #: 164
The Stig..
Newport Pagnell
Yes as Wil said have gone back to the PH 2, the 3 was to lairy and lost me lots of mid range power.
The standard MG Metro cam is good in a turbo to(not turbo item)
JF
I use 1.5 ratio rockers too.
giallofly
Member #: 164
The Stig..
Newport Pagnell
So more lift at with the same duration, me to.
so no-one likes the phase 3 then ?
giallofly
Member #: 164
The Stig..
Newport Pagnell
Not unless it was an all out top end only motor.
