Home > Show Us Yours! > My Austin 1300 as of today
Not done much, but I thought I'd get two pictures up.
If you take this:
And this:
That should equal fun right?
I'm building a new 1100 engine for it.
I bet cars in norway turn from 0-to rust in less than they can 0-60!
IIRC was that the setup you bought from ebay a while bck?
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
The second picture took a while to load for me, was a big white space, I though that the snow had covered the whole car before he had the chance to take another picture!
Cool car, even cooler setup!
stefaz
Member #: 1656
stoke-on-trent
nice setup v - should equal fun
should be fun V its not snowing there already is it ?
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I will answer that as I know too:)
no, its not snowing yet, that picture is old. I hope it will not snow in a months time at least, but it has started to be icey in the mornings, its below zero in the night:)
Edited by miniminor63 on 25th Sep, 2007.
I hope it'll snow tomorrow! Bring it on!
I've got these:
Look at my perfect period boost gauge people:
Kean
Member #: 341
aka T2clubby
South Staffs
Gimmie!!!!!!!!!
Please....
So people. Specs are:
-1100/+040 Hypatecs
-202 head uncertain if I'll showe some 940 valves in there
So, two questions:
1. Which cam would be good for this spec? MG Metro? 266? Remember, road car no silly power.
2. CR. As I'm running a suck through setup, there's no intercooler. What boost can I safely run on this, and which CR would be beneficial then? It'd be nice to run 10psi, because this would mean I get on the red section on the boost gauge :)
benjamin
Member #: 621
nsw austalia
-1100/+040 Hypatecs
So, two questions:
head use 202 and bigger valves if you want but turn them down so you dont have to pocket block remeber to use 1275 springs and may be nessesary to shim the springs.
1. re-13T graham russel cam
2. CR. of an 1100 is around 8.5:1 standard so should be fine
Edited by benjamin on 15th Oct, 2007.
1152cc turboed mini clubman, most powerful 1.1L a-series?
http://boostmini.justboard.net/
AL
Member #: 1347
Croydon (South London)
nice boost gauge. Liking the volvo in the background *wink*
really like this little car!
good work mate *happy*
Turbo Shed
Member #: 30
Epsom, Surrey
the air filter looks a little restrictive.
i wish it would snow like that in england, all roads would be closed so no chance in getting to work!
V,
i'd fit a temp sender and just check for aircharge temps to determine your max boost. so many things can affect it otherwise.
dan
Member #: 93
looks awesome vegard
Progress on the turd:
Polished and balanced crank:
Bored 040
I think I'll bin this...
thoses tyres rule!!
'il have some Aoo8's with extra snow studs please'lol
Moz
Balanced rods:
Mine cracked just like this!
Loving the project V!
Edited by theoneeyedlizard on 26th Oct, 2007.
miniminor63
Member #: 672
Oslo, Norway
dont think its to unusual really. I cracked an S pulley the same way. I had a huuge oil leak a second after it happened:) And when i took it apart it was in two pieces.
CR#
Member #: 1367
Cape Town, South Africa
I’m quite interested in the suck through system that was on originally, what turbo is that and how did u find it ran?
I've never run this system to be honest. Bought as a kit. It's a T3 of some sort. Infact, it looks as a bog standard Metro unit. I relly should get a smaller and modern turbocharger, but I'll use this for now to get it running.
Hypatecs on rods:
