| Home > Show Us Yours! > The DON Datalog...... | |||||||
25th Sep, 2007 at 01:32:17pm
See picture below. This was the 12.790 second run.
25th Sep, 2007 at 01:35:03pm
Try starting different threads for each little gismo on this fantastic car of yours now will you On 13th Jul, 2012 Ben H said:
25th Sep, 2007 at 01:42:22pm
OK mate will do!
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
25th Sep, 2007 at 01:59:29pm
Tom,
25th Sep, 2007 at 02:00:53pm
No, its very easy, one input from a clutch switch into the ECU then a few drop-down boxes in the software.
25th Sep, 2007 at 09:33:37pm
Great datalog .... interesting insight into the engine.
25th Sep, 2007 at 09:45:19pm
Looks like boost is at it's max at around 7k rpm and that might be a good time to tip the no2 in.
25th Sep, 2007 at 09:53:17pm
On 25th of Sep, 2007 at 09:33pm RogerM said:
Great datalog .... interesting insight into the engine. Neil ..... don't think your 5spd will take kindly to being flat shifted .... best take it out, sell it to me for 50p and a SC gearset .... ![]() Bargain!! Except like you I couldn't stand the noise.... It was just a thought as it seems to help keep the boost up in between gears |
25th Sep, 2007 at 10:21:26pm
Glad that all makes sence to you lot, am confused, would be nice to understand it one day lol |
25th Sep, 2007 at 10:24:51pm
right Rick, its a piss balll to work out , the bit on the left is when toms sat idling, and the bit in between is him accelerating and the righthand most is the end,lol. bish bash bosh job done.
25th Sep, 2007 at 10:24:53pm
On 25th of Sep, 2007 at 09:45pm danboy said:
Looks like boost is at it's max at around 7k rpm and that might be a good time to tip the no2 in. Would it not have been quicker to hang on in third up to 9k and then change gear normally. Just questions from the log as I know nothing about drag racing!!! Regards dave That run was using the gas in second gear onwards, as I mentioned in another post the car seemed a bit down on power on sunday, as the previous best of 12.796 was without gas, whereas that run of 12.790 was with gas. I've yet to investigate where the power has gone! As for hanging on till 9k and then changing, the power peaks at 7000rpm but is still strong to 8000rpm, after that it starts to tail off quite quickly, hence the shiftlight is set at 8100rpm, and I grab the next gear as soon as I can when I've registered that the light has come on. Shifting at around 8000rpm moves the engine back down to 6500rpm or so; at this point it is making 210bhp, so you are well in the power all the time. As you can see from the video it is all quite frantic, so there is not the time to be looking at the tacho or boost gauge, in fact I don't think I've ever looked at either during a run, the tacho is useful for getting an idea for starting, and the boost gauge for a quick look during a blast down the return road!
25th Sep, 2007 at 10:36:31pm
FRANTIC is the perfect description
