| Home > Help Needed / General Tech Chat > fitting cooper s brakes | |||||||
![]() 152 Posts Member #: 1662 Advanced Member manchester |
25th Sep, 2007 at 05:40:37pm
i would like to fit 10inch wheels to my 1989 mini which currently has the standard brakes, so i will have to fit the cooper s brakes, is there anything else i will need? is it just a straight swap, will they work fine with the current master cylinder etc? cheers |
25th Sep, 2007 at 05:55:26pm
they should work with the current master. Another possibility is to get some 7.9" discs (8.4" discs turned down) and some alu calipers from minispares or the like. that would give you good brakes and also let you fit 10" rims. |
25th Sep, 2007 at 06:08:59pm
25th Sep, 2007 at 06:11:35pm
will alu 4pot 7.9 inch work with 10inch wheel?? thanks |
25th Sep, 2007 at 06:18:05pm
yep. On 28th Aug, 2011 Kean said:
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
25th Sep, 2007 at 08:46:18pm
Will the S calipers fit the 8.4" hub? (using 7.9" disk) are the centres of bolt holes etc the same?
25th Sep, 2007 at 09:00:24pm
All will bolt straight up ...... not sure why you'd want to ..... but you can. Every day is a school day ...........
26th Sep, 2007 at 07:59:59am
you can get 10" wheels to fit any type of brake set up. even 8.4" vented discs and standard 4 pots. the main thing is chosing a set up that works with the wheels you would like to fit and how nice you would like it to handle. |
26th Sep, 2007 at 02:43:10pm
On 25th of Sep, 2007 at 09:00pm RogerM said:
All will bolt straight up ...... not sure why you'd want to ..... but you can. |
