| Home > Wanted > 18 tooth GT ratio 4th gear | |||||||
11 Posts Member #: 1237 Member |
28th Sep, 2007 at 05:04:49pm
Hiya, if any one has one of these I would be grateful.
194 Posts Member #: 1297 Advanced Member Sunny Stockport |
28th Sep, 2007 at 05:19:19pm
I think I spotted one today when tidying the garage, not sure where I put it though! I guess you're talking for an early 14mm mainshaft not the later 18?
![]() 465 Posts Member #: 1972 Senior Member Worcester |
28th Sep, 2007 at 05:25:38pm
Yeh the original 14mm ones is wot im after. (got my m8 jev1987 to post cos i didnt hav an account!) Let me know wot nick it in if u hav got one,
28th Sep, 2007 at 05:43:19pm
Got two, both used but in good nick. Very slight wear to the front 'point' of the syncro teeth and one has a slight chip on the coating on the syncro cone surface. Bearing surfaces and gear teeth are unmarked. I can get a pic or two if you're interested? |
28th Sep, 2007 at 06:22:32pm
Yeh pics would be good, am definately interested as the synchro coating has totally gone on mine! |
28th Sep, 2007 at 07:19:36pm
First pic is the one with the chipped coating but it has slightly better syncro teeth.
28th Sep, 2007 at 07:34:15pm
TBH think id be better off with the second one with the better synchro coating, how much u want for it inc postage and where abouts are you?
28th Sep, 2007 at 07:45:39pm
How about £15 incl postage?
28th Sep, 2007 at 08:35:35pm
PM sent, cheers |
28th Sep, 2007 at 08:38:13pm
28th Sep, 2007 at 09:13:09pm
Done. I can add it to the other stuff if you want so no extra postage?
On 28th of Sep, 2007 at 08:38pm Vegard said:
I'll take the bad synchro one for £8 :) Edited by neilj1678 on 28th Sep, 2007. |
29th Sep, 2007 at 08:23:03am
Yeh thats fine i was after the other one with the better synchro coating |
29th Sep, 2007 at 10:17:14am
I'll take the bad synchro one for £8 :) It's yours Vegard if you still want it? Regards Neil |
29th Sep, 2007 at 11:11:54am
29th Sep, 2007 at 12:01:06pm
pm sent Vegard |
