Home > Help Needed / General Tech Chat > Snapped bold on turbo =/
in advance sorry about the lack of quality... i unfortunatly snapped a bolt from my turbos exhuast elbo (pics to follow) and another is going to snap also by the feel of it. is it ok to drill this out and put in slightly larger bolts for next time arround??
also have a few pics of the carb. im hoping you will be able to help and say if im missing anything from anyware as i know you guys are S**t hott :)
cheers paul
[color=red]not broken[/color]
[color=red]broken[/color]
other pics i got
wish i was aloud in the kitchen with my bmx!!lol
Moz
If you can weld a nut or something onto it, you might extract it like that.
But drilling it out is an option....a difficult one at times.
Buy a very good drill bit, if you can, a proper carbide bit. These will drill through even the hardest steel.
You can then either drill it out entirely, or drill just big enough and run a tap through the hole to reclaim or re-cut new threads.
You won't put a bigger bolt in, there isn't room in the casting.
Good luck drilling them out, the heat cycling makes them go pot hard, you'll probably find you can't touch it with a normal drill bit, as Stevie says you will prob need a carbide bit.
Welding a nut to it is a good thing to try first, the heat from the welder will assist you trying to get it free.
Turbo Shed
Member #: 30
Epsom, Surrey
if it was me, i'd use one of my other spare turbos. failing that welding a nut on sounds a good idea and add some extra heat for good measure
I had to drill 3 of mine out, the drill bit was about 10mm shorter by the end as it had to be re-sharpened so many times! *laughing*
It was a mission but do-able. *oh well*
Just remember if you drill the stud out don't start drilling what looks to be the centre of the stud as it isn't the centre (if that makes any sense) you have to take into consideration the thread depth that will be visable on one side but not the other!
Start with a small pilot drill then go from there.
get them parts in the dishwasher
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Use a pilot drill first as matty says to be safe. If you lucky you maybe able to use those stub extractors.
What turbo is it? Thought elbows had round hole.....
On 19th Jan, 2010 wil_h said:
Get the carbide drill bit though....they are awesome !!!
A bolt snapped off in my supercharger recently, so I tried to drill, then use an easy-out exctractor.
its worth noting, when using such tools, it pays to buy quality ones and not cheap pish....because the exctractor broke in the bolt I was trying to remove :(
The carbide drill drilled through it with ease !!!!!! Finally got the bolt out :)
the turbo is a standard metty turbo one, its just got the gasket covering it a bit. im going to try a stub extractor from work as i cant weld anything to it as it is achually inside still :( cheers for the comments ill bet trynig the drilling ifd i cant get it out =/
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
A masonry bit is carbide at the end so grinding the right angle on will make it possible to use on steels. *wink*
