Home > Help Needed / General Tech Chat > subby differences
Carl
Member #: 95
liverpool-on-sea
are the over all dimensions the same on a twin bolt subby and a single bolt subby? in particular the gap inbetween towers, in my hast i for got to make a bar to go in between the towers and chopped a bit out of the middle/back on my toyota conversion and it seems the towers have moved in a bit so the only subby ive got to measure is the later one.
cheers.
I would think theyre idententical, only difference i can think of is the bulge at the front with the later ones.
miniminor63
Member #: 672
The oversills police
Oslo, Norway
I would not go with think in this situation, maybe someone can measure? I can possibly do a measurement from inner bolt to inner bolt on a twin bolt subby tonight. Otherwise, could you bolt it to the car and weld a bar on maybe?
Edited by miniminor63 on 4th Oct, 2007.
I am sure they are identical; that is the centre of the towers on twin and single bolt frames.
I wouldn't guarantee that the pressings used for the 'towers' is the same however - these would no doubt vary between each frame.
Carl
Member #: 95
liverpool-on-sea
if you could measure thatd be great
cheers
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
On 4th of Oct, 2007 at 01:00pm Carl said:
in my haste i forgot
Haste it what you call it? Youre just scared a certain mates mini is goin to be up and atom faster
miniminor63
Member #: 672
Oslo, Norway
sorry, I did not get a chance today. Will try tomorrow.
danboy
Member #: 1381
The distance C/L to C/L of the bolts on a late single bolt subframe is 30 & 1/4 ".
I no longer have an early twin stud to measure.
Regards
Dave
graemec
Member #: 1424
Carnforth, Lancs
Any good?
danboy
Member #: 1381
Yes they are the same then!!
Regards
Dave
Carl
Member #: 95
liverpool-on-sea
thanks people, graemec thats perfect thankyou.
