Home > General Chat > fuel filters
mr t bo
Member #: 78
milton keynes
getting close to fitting my engine yet again. have been running my new fuel lines and was wondering what sort of fuel filters everyone is using? and also where abouts they are placed in the fuel system?
jonny
T3Tone
Member #: 252
Sunny suffolk
I use a Purolator in line jobbie from minispares (about ?13) with the 5/16 unions, Its fitted between the tank and pump so its not under pressure. You can also dismantle them for cleaning or replacing the filter element.
-MINI CLUBMAN 1380 TURBO-
I use a metal bodied champion one, I basicly opened all the boxed in halfords looking for a metal filter with hose tails on, they loved me!!
billydude
Member #: 48
Leicester
I use a metal bodied nissan injection filter
I did the same as Jim except at my local motor spares shop *smiley*
Arno
Member #: 233
Beugen, Netherlands
Same for me, they keep on loving you if you bring them a case of beer once a year.
The same route goes for brake pads and hoses, steer joints etc. etc. you name it.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I did the same as jim but ended up witha plastic one... fine for pre pump.
Alex
AlexF
b12
Member #: 247
Kent/Surrey Borders
i have a glass one with chrome end .. I think its Purolator
I have put it between the pump and the regulator ....
I think it was Jimster who said that may not be a good idea cos of the pressure
Now I am gunna have to move it I suppose !
S
TurboLessTosser
Would a TPI Mini filter work???
AV-R Technologies
Member #: 345
Guildford Surrey
Use a golf GTI 1.8 MK1 or MK2 inline metal filter. These are full flow and pritty cheap. You could also use a Bullet full flow motorsport filter. Most of the other types we've tried over the years just have to much fuel restriction.
http://www.avonbar.com
Gibbo
Member #: 34
Avonbar, just to confirm you're on about the pre-filter for the pump right?
Then use a cheapo plastic one after the pump is OK?
AV-R Technologies
Member #: 345
Guildford Surrey
correct we would always recon on fitting a pre pump filter.
rover 114gti filter before the pump, then i bought some hose connectors and hey presto a 10mm fuel pump for £12
jamesfawcett
Member #: 218
Bingley, West Yorkshire
im using a plastic halfords one between the pump and the engine in car by the handbrake, i arnt getting any restrictions with full rubber 8mm piping.
I just bought a Astra 16V one. The same as before and it was £10.
Scruffy
Member #: 328
Seaford Rise, South Australia
Any injection one will work unless it is fitted to a white Turbo with green wheel arches!!!! *smiley*
On 5th Sep, 2011 Vegard said:
LOL at nick
Oh crap :)
minimark
Member #: 19
newcastle
thats just as well , cos its a white turbo , with green arches AND A GREEN ROOF !!!
