| Home > Wanted > Roll cage spreader plates | |||||||
7th Oct, 2007 at 05:17:58pm
Anyone got any spare plates for mounting a cage?? Or any 3mm plate to fab some from?
969 Posts Member #: 47 Post Whore Not very sunny swanage |
7th Oct, 2007 at 05:32:57pm
see if you can find a local fabrication shop.... we use one round here when makeing up rigs etc for work, they have loads of stock plate etc, and are very good at working with dodgy 'this big with a bend about here-ish' drawings. the one we use is really quite reasonable on price as well..... worth wondering in with cash also, often makes a big differance..... And on the 7th day........... God created turbochargers! |
7th Oct, 2007 at 06:08:10pm
I've got some spare 3mm. PM & I'll sort something out for you. On 19th Jan, 2010 wil_h said:
7th Oct, 2007 at 06:16:58pm
Get down to the metal supermarket in Coventry. They will cut to size the bits you need, and I doubt it will cost much.
http://www.twin-turbo.co.uk
7th Oct, 2007 at 06:56:10pm
1/8" plate can be more common than 3mm and is near as dammit the same (3.175mm).
1050 Posts Member #: 764 Post Whore Staffordshire |
10th Oct, 2007 at 06:07:39pm
On 7th of Oct, 2007 at 06:16pm Ben H said:
Get down to the metal supermarket in Coventry. They will cut to size the bits you need, and I doubt it will cost much. http://www.metalsupermarkets.com/ Kean, The West Brom one is closer... http://data.gointranet.com/cgi-bin/unitloc...bromwich&cl=509 |
10th Oct, 2007 at 07:08:23pm
Cheers guys |
12th Oct, 2007 at 01:22:10pm
i need some aswell |
