| Home > Help Needed / General Tech Chat > Quick DV question | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
8th Oct, 2007 at 01:51:06pm
Am I right in saying that if you sit there revving the car not moving, that the dump valve does not operate? Does the engine need to be under load for the DV to work or have I just got a duffer. What sort of pressure is required to move the diaphragm in the DV?
8th Oct, 2007 at 02:10:10pm
if you give it a hellishly good boot it may go if if your running enough boost
8th Oct, 2007 at 02:20:50pm
It's does take a lot of welly to get it to dump without load. In the 13's at last!.. Just |
8th Oct, 2007 at 02:33:54pm
Ok cheers, i'll try the lead foot option then! |
8th Oct, 2007 at 02:39:57pm
Just a thought then, if the turbo is still spinning up as normal but car is not moving how/where does the boost escape to if the DV is not operating? |
8th Oct, 2007 at 03:18:07pm
The turbo will not be spinning up 'as normal' without load. In the 13's at last!.. Just |
8th Oct, 2007 at 07:08:04pm
As above ^^, but why not prove it to yourself. Take a pipe of between the compressor and the plenum. The give the engine a hand full of revs and while doing this put you hand over the pipe from the compressor. You will (should) feel air pumping out, but not much.
http://www.twin-turbo.co.uk
8th Oct, 2007 at 08:36:40pm
Handbrake on assuming it works properly, select 1st, plenty of revs, slip clutch to load engine up, you will see boost then without moving. Won't do your clutch much good though so don't make a habit of it.
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
8th Oct, 2007 at 09:48:48pm
^^^ as tom says....
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
![]() 1566 Posts Member #: 36 Post Whore Basingstoke |
9th Oct, 2007 at 09:26:09am
where have you plumbed the vac in to? If you've done it before the butterfly you won't see vac and it won't open. Hope that makes sense, i'm tired. |
