Home > Help Needed / General Tech Chat > Carb question
1380turbo
Member #: 1211
Working up the BHP ladder.
Anybody know what the hose is for that seems to run from the plenum side of the carb to the butterfly side?
Is this the one that you mean?
If so, it's the part-throttle lean off pipe.
1380turbo
Member #: 1211
That is indeed the one. Anybody understand its operation?
at part throttle, it creates a small amount of vacuum in the floatbowl, via restrictions in drillings in the carb, to help lean cruise mixtures.
It created a misfire issue with my car. A lot of people would advise you to block it off.
1380turbo
Member #: 1211
Thanks guys! :)
philc
Member #: 1346
bromsgrove
I blanked mine off at one point seemed to run better
Turbo Shed
Member #: 30
Epsom, Surrey
mine ran lick crap when i blocked it off. then again everything i do seems to have an adverse affect
Mines blocked off and ran fine.
if you want the best of both worlds stick a solenoid in it, then you can try either.
I cant see any reason why it would cause running problems if the carb is set up right ? and the air bleed hole into the chamber from the plenum isnt blocked.
if it splits or leaks it can cause a problem, so on my car where off throttle economy is not important, its safest to blank it off.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Like the challenge carb, blocked off. Theres also a balance pipe fitted, god knows how it works though.
