Home > Technical Chat > Turbo Cylinder Head....
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Has anyone got pics of a standard turbo head inc chambers & ports? Cheers
On 19th Jan, 2010 wil_h said:
RogerM
Member #: 1217
I like nice quiet girly Minis
Cheltenham, Gloucestershire
How quick do you need them buddy?
If you give me time I'll pop a head of a block at the weekend.
Have a look at my homepage. There are some pictures of a Spi head there. The ports and chambers are identical.
Edited by Vegard on 10th Oct, 2007.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
thanks chaps :)
Whats your homepage Vegard??
Edited by Jason G on 10th Oct, 2007.
Oh, I thought that was in my profile.
http://home.online.no/~lyngset/pictures.cf...t=97&pDispType=
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Cheers Vegard, just need some pics to compare my head too. I am an amateur & don't know what I'm looking at.
Thanks to steve & Jon also
Edited by Jason G on 11th Oct, 2007.
andywaller
Member #: 1826
Maldon Essex
its been worked!
if you need a skim on that and your not in too much of a rush, i can do it for you!
Jason G
Member #: 1459
En-suite user
Braintree, Essex
I think just a good clean up is in order. Had no gasket issues, so I don't think a skim is in order. Cheers anyway andy *wink*
No. 4 piston is damn oily, so rebuild needed anyways.
Another head would be nice spare parts :)
it also looks to me that the valve guide bosses have are standard! have not been played with
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Good call steve. :) Remove guides & remove material?
Its just knowing the differences between standard & modded...then I can understand whats involved.
So you chaps picking at it helps. :)
this is a 295 not a 940 (and it was painted red when i got it), but it shows the obstruction the valve guide boss's make:
with:
without:
Chamber is modified, ports look untouched. (The important part)
Sir Yun
Member #: 1592
Smart Guy!
to be honest i doubt the guide boss is much on an issue with the kind of cams used for turboing..most of the time it is not such a restriction below, say.. 0.450 lift.
just my view:
these days i port a head with the guides in. i just push them back equaly in all ports as a guide then grind the proper shape taking out quite a bit of the guides as well.
i keep the guideboss in place before and after the guide but the sides are ground down quite deep.
porting with guides in keeps you from getting your hands torn off by your BIG grinder while catching in the hole normaly filled with guide.
of course the guides are replaced afterwards.
for a turbo i would probably work on the exhausts a lot..trying to keep enough metal around the guide
that said i have no experience with forced induction heads (having a go at a SC head next week) but have a reasonable grip at NA heads
the guide boss is "one" of the MAIN bottle necks, sir yun
Indeed it is. The inlet ports on a 940 are not that bad, but the exhaust ports are rubbish.. There's LOTS of room for improvement there.
Jason G
Member #: 1459
En-suite user
Braintree, Essex
Cheers Vegard & Benross :)
