Home > Help Needed / General Tech Chat > Need Some help :)
Markie_D
Member #: 1660
Formally Mini_Uk
London
Which way round does this go for the short shift gear stick to go Into.
1.
http://www.turbominis.co.uk/_photos/random...os/683/4191.jpg
Or 2.
http://www.turbominis.co.uk/_photos/random...os/683/4192.jpg
And you know that lever on the gear stick, which u pull up to make it go into reverse
http://www.turbominis.co.uk/_photos/random...os/683/4193.jpg
Well as u pull it up, what makes it work. as from the pic above, it dont seem to do anything ?
can someone help us out please
Cheers :)
Shit Happen's
First question, it goes lower down like in pic no 2.
Second question, on the plate that screws on the bottom there should be a bit of metal that stics up to prevent the stic going into reverse.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Oh right.. so as u pull it up, it helps to selected reverse.
Cool.. thanks for that :)
Shit Happen's
as you pull it up it will clear the bit on the bottom plate so reverse can be selected.
Tazzy
Member #: 1677
Netherlands, The Hague
On 18th of Oct, 2007 at 05:37pm Mini_Uk said:
1.
Or 2.
Markie_D
Member #: 1660
Formally Mini_Uk
London
Errm, how u do that Tazzy :)
Im sure it's been told b4, but im to
*tired* to look tonight.
Shit Happen's
Place the letters IMG inside these brackets [] before the Http link (no spaces)
Then place the letters /IMG also inside square brackets after.
So
[ IMG] your file [/ IMG] but remove all the spaces.
Tazzy
Member #: 1677
that trick works on 99% of all forums
turbo hogster
Member #: 178
stowmaket suffolk
make sure you shove loads of grease on all moving parts if not it wear out in know time.
Ive been told that that applies for all things in life *wink*
turbo hogster
Member #: 178
stowmaket suffolk
nic you do have a crude sense of humor mate lol.
i always pack with loads of grease stops the water getting out lol
Markie_D
Member #: 1660
Formally Mini_Uk
London
Testing 1.2.3
It works :)
Thanks for that Tom..
Edited by Markie_D on 19th Oct, 2007.
Shit Happen's
Jordan
Member #: 1392
Pointless Post Whore
Liverpool, North west
On 19th of Oct, 2007 at 09:29pm Mini_Uk said:
Testing 1.2.3
You should have 4 and reverse. *tongue*
Testing 1.2.3
someones been geting enough sleep
ohh noooo .
Jordan
Member #: 1392
Testing 1.2.3
I couldnt resist. Plus i got bored
