| Home > 998cc > 998 as opposed to 1275?? | |||||||
![]() 87 Posts Member #: 2018 Advanced Member Witton Park, Northeast |
24th Oct, 2007 at 07:35:50pm
Ok I've been going down the route of turbo'ing a 1275 and am coming across stumbling blocks with regards to finding the right block and the right bits and even looking for a metro turbo engine and gearbox complete, but struggling. I'm looking for at least the 120BHP mark.
24th Oct, 2007 at 07:50:27pm
You can, however it may cost more in the long run, and the engine will be running at a higher stress level than a 1275 to make the same power.
447 Posts Member #: 668 Senior Member newton aycliffe (near durham) |
2nd Nov, 2007 at 12:50:50pm
why you struggling to find a 1275cc block? any unmolested one will do! wont it? |
2nd Nov, 2007 at 12:57:18pm
Have a read of this thread:
2nd Nov, 2007 at 08:45:20pm
There is a nice thread by I think Tom Fenton on here which desribes the difference between MG Turbo engines and non turbo 1275s so have a search of that. In short any 1275 can be rebuilt for turbo use given your carefull with piston and compression ratio choice. You can also get a bottom end kit from quite a few reputable engine builders such as Avonbar for less then a grand.
On 7th Nov, 2008 Nic said:
3rd Nov, 2007 at 10:07:44am
the advice i gave DemonPixie is get a compleate turbo metro with ALL the anciliries
![]() 3756 Posts Member #: 1709 I like granny porn. LONDONSHIRE |
3rd Nov, 2007 at 10:42:04am
confused.com.... On 2nd Oct, 2009 Vegard said:
I bet my first wank came quicker than your first mini turbo These new modern turbos with their quick spool up time, would make the competition harder. On 15th Aug, 2011 robert said:
phew!!! thank you brett for smashing in my back doors .( not something i imagined writing... EVER) |
3rd Nov, 2007 at 02:04:38pm
On 3rd of Nov, 2007 at 10:07am BENROSS said:
the advice i gave DemonPixie is get a compleate turbo metro with ALL the anciliries because it will be much cheaper in the long run than sourcing all the other bits to make it into a turbo charged engine hence she may be a little confused ? Your right that's the best way but I just wanted to say any engine will do if complete Metros or turbo lumps were hard to get. On 7th Nov, 2008 Nic said:
