| Home > Help Needed / General Tech Chat > cam/ oil pump. | |||||||
![]() 862 Posts Member #: 1660 Formally Mini_Uk London |
26th Oct, 2007 at 10:17:51pm
I put my oil pump in the other day, and noticed i pushed the cam through to the other side. i pushed it back it. but just want to know could it have messed anyway up, like the set up.
Shit Happen's |
![]() 1913 Posts Member #: 1392 Pointless Post Whore Liverpool, North west |
26th Oct, 2007 at 10:34:20pm
Wouldnt seal the pump with sealant just a new gasket as sealant may get into the line of the oil flow.
Back once again like a renegade master |
26th Oct, 2007 at 10:41:44pm
Assemble the entire cam drive assembly, THEN fit the oil pump. THe cam will not move much then. If it does, have you remembered to fit the cam thrust plate? Fitted with three 1/4" bolts? On 13th Jul, 2012 Ben H said:
26th Oct, 2007 at 10:59:03pm
Put a small amount of engine build lube into the oil pump, if you fit it dry it will take forever trying to get it primed before initial startup.
26th Oct, 2007 at 11:58:29pm
On 26th of Oct, 2007 at 10:34pm minimadj said:
Wouldnt seal the pump with sealant just a new gasket as sealant may get into the line of the oil flow. As for the cam how far has it moved towards the timing end? Couple of mm? More like 10mm. I pushed it back in now.. seems ok.. Shit Happen's |
27th Oct, 2007 at 12:00:31am
On 26th of Oct, 2007 at 10:41pm Vegard said:
Assemble the entire cam drive assembly, THEN fit the oil pump. THe cam will not move much then. If it does, have you remembered to fit the cam thrust plate? Fitted with three 1/4" bolts? Thats what i didn't do should of at first..
But thats done now thanks :) Shit Happen's |
27th Oct, 2007 at 12:02:25am
On 26th of Oct, 2007 at 10:59pm Tom Fenton said:
Put a small amount of engine build lube into the oil pump, if you fit it dry it will take forever trying to get it primed before initial startup. Make sure the cam has meshed properly with the drive into the oil pump. I had it all primed by steve,(BENROSS) the main man
Cheers ... Shit Happen's |
