| Home > Help Needed / General Tech Chat > DIY - Turbo Rebuild | |||||||
158 Posts Member #: 551 Advanced Member Ashington W.Sussex |
30th Oct, 2007 at 10:35:11am
Hi all
30th Oct, 2007 at 08:55:26pm
i've done my own, it was ok but to be honest the shaft had too much wear.
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
30th Oct, 2007 at 09:28:20pm
I have done one on my Iveco van years ago and it did 40,000 miles with no problems and one on my min van that did over 15,000 miles no problem.
30th Oct, 2007 at 10:27:45pm
You need to have access to a bead blaster. Apart from that, quite simple. On 13th Jul, 2012 Ben H said:
30th Oct, 2007 at 11:09:01pm
I need to rebuild one at some point and was wandering if you got the turbo balanced afterwards? Edited by Rob H on 30th Oct, 2007. Isambard Kingdom Brunel said:
31st Oct, 2007 at 12:30:03am
As far as ive been told many times, as long as you mark the rotating assy and assemble it all in the same position the balancing shouldn't be effected.
487 Posts Member #: 1495 Senior Member |
31st Oct, 2007 at 07:08:34pm
I had to replace the bearing housing on mine which fixed the play. £40 tho for the housing |
![]() 834 Posts Member #: 2017 Post Whore Warwick. |
31st Oct, 2007 at 07:36:27pm
i do this every day at work, its fairly simple, shafts are usualy fine which ever position there put in, we dont have anything there to cut the shafts into balance so we just rotat the compresser wheel, we use a piece of equipment that rotates the shaft then measures the vibration at different points
David. |
